85 Extra Cab Saved from Crusher
Old Oct 20, 2014 | 04:58 AM
  #541
Gizler00's Avatar
Good info Terry.
It still amazes me every time with the differences in all these trucks and harnesses. I was just telling one of the students last week about hos many of these trucks I have owned, and not a single one was the same or had the same features as the next. Crazy
Old Oct 20, 2014 | 09:12 AM
  #542
jason in tn's Avatar
Not perfect but I got a start to your brown interior buddy.
The door panels are in great shape just need cleaned up. Perfect dash pad, got it out without breaking the vent yeah me lol. SR5 gauges needs the lens replaced. Let me what If any of it you want/need I grabbed it all for you buddy.
Old Oct 20, 2014 | 05:11 PM
  #543
kornhuskerwizard's Avatar
I'm running a brown/tan whatever you want to call it dash pad in my runner.I used it because it was setup to hold the inclinometer.
Old Oct 20, 2014 | 06:07 PM
  #544
I've got a grey pad cut for an inclometer if your interested, it came with all the parts I got for the wife's 88.
Old Oct 24, 2014 | 11:33 PM
  #545
Terrys87's Avatar
Hello Mark...I got bit by the Toyota Changing Plugs Syndrome again. There is a third style of plug that I had not caught on to. It looks just like the mini pin plug but is a bit larger, Urgh!!!
Thanks Jason.. The brown or tan interior will look so much better then the gray. Appreciate it. We get a chance we can meet up some time and do a parts swap.
Hello Chris... I have not been able to find an inclinometer, those are hard to come by. I eventually will find one, just have to be patient. I am about to give up on dash pads. I have had 2 perfect dash pads in my runner and last winter one cracked 4 inches over nite. I seen yesterday my 86 has a hairline crack in one area and you can see with just the right angle an light, the foam has separated under the vinyl and it is just a matter of time before the vinyl cracks. I am going to start looking at those overlays on ebay.
Old Oct 24, 2014 | 11:46 PM
  #546
Terrys87's Avatar
I was able to go to the bone yard but wasn't able to stay as long as I would of liked. I did score an SR5 Main Harness for my truck. It came off of a rusty, beat up, truck that had some panels cut off of it. This is one of the most loaded trucks I have ever seen. It had the sun roof in it.
The Main Harness I got has the following factory options.
Cruise Control ( I wont hook it up)
Map Light
Glove Box Light
Electric Antenna
Electric Door Locks
Lights in Doors
Electric Mirrors
Wiper Delay
Head Light Reminder
Door Reminder ( I think it is what it is)
Low Level Fuel Light
I am sure there is something I missed. I just need to replace a blinker plug. The only problem I have run into so far is the fuel/tail light harness is a different plug. I will need to go back and get it in a few weeks. I should of grabbed it today but the ground was wet and I was running out of time. In the mean time, I will try to just hook up the fuel pump so hopefully I can just get the truck to move under its own power. I also grabbed the head light/fuse box harness. I am sure I have an 86 Injector harness so maybe I am done swapping harnesses. This one looks to be great. I can start assembling the dash now.
One loaded SR5 harness. I will eventually add some of the features at a later time. Just want to get the basics and get it running.
I was able to grab a tail gate panel. It was rough looking but a little hammer and dolly and some sanding has it looking ten times better. Once I get it painted it will look better. Later on I am going to get a roll in or spray in bed liner and then paint over that and it will hide any imperfections. One more piece to getting it closer to assembled.
I was working on getting this piece sanded and let Hunter work on getting some farm pieces ready for paint and he is getting the sanding part down real well. He helped save some time.
Old Oct 25, 2014 | 02:13 AM
  #547
Cyberhorn The Dragon's Avatar
headlight reminder too sheesh talk about yer highest end SR5 lol
Old Oct 25, 2014 | 08:54 AM
  #548
Terrys87's Avatar
Hello Cyberhorn.. After thinking about this harness and with it being an 85, solid axle, fuel injected, I am thinking of trying to get all of the features working in the long run. have the possibilty of having a unique truck if all was to come togheter as planned. It will take some time to get all of the features working. The door panels which are the hardest one to find was laying in the back of the truck and got ruined. That was a shame. It will take a while to find all of the switches for the mirrors and such but I am really thinking of trying to go full blown on the SR5 thing.
Old Oct 25, 2014 | 08:55 AM
  #549
Terrys87's Avatar
I have been cleaning and installing the power steering resivoir, harness, AFM, and coil. Starting to look like a engine bay again. Also got some second gen door pockets to install at a later time.
Old Oct 26, 2014 | 03:59 PM
  #550
rustED's Avatar
Nice work Terry, your trucks looking great!
Old Oct 26, 2014 | 05:58 PM
  #551
Lookin good!!
Old Oct 27, 2014 | 06:17 AM
  #552
Nervo19's Avatar
That's not where they go. Even I know that.
Truck looks great.
Old Oct 27, 2014 | 11:54 AM
  #553
Terrys87's Avatar
Thanks Ed...I making small steps.
Thanks Chris... I am hoping to get it together one of these days.
Hello Nervo19...I got a kick out of that. Thanks, I hope to get it on the road.
Old Oct 27, 2014 | 12:01 PM
  #554
Terrys87's Avatar
I should of grabbed the fuel/tail light harness out of the donor truck in Springfield but the ground was wet. Luckily the Joplin salvage has a two wheel drive camper and the fuel harness will work to get it to move under its own power. I will eventually go back and get the harness. Also when I was there I only had one hour to grab as many parts as I could. It was Friday and he was closing early.
Did get a few things in. I have several different things going on so wanted to get something done.
I disabled my door buzzer. I have shown this in the past. Some remove the buzzer box and then the dome light wont work. I just bend the tab back to keep it quite.
Here is the Speed Control Box. I dont have all of the parts needed to make it work but it is a start.
Installs below fuse box.
Got the Blower Box cleaned and installed. One of the toughest trouble shooting I have done is on this resistor. There are 3 and 4 pronged resistors. I will need to order a 4 prong resistor later.
You have to have the Glove Box Light option installed in the main harness. The bulb is on top and the bottom bracket has a tab weled to it to control the light. A new part I will be keeping an eye out for when in the yards.
Door Control Box.
It goes above the clutch pedal. I dont know what it does, but it looks good doing it.
Got the AC Evaporator, Blower and Heater Core assembly in.
Old Oct 27, 2014 | 06:00 PM
  #555
Nice pics Terry!!how's the shop heat coming along??
Old Oct 31, 2014 | 02:42 AM
  #556
Terrys87's Avatar
Hello Chris..I need to get back on the shop again. I still need to go get my wood heater and that one is going to bite if I dont get it done. We are having a cold spell for a day but the cold days are coming. I am going to try to get something done in the shop this week as we are going to warm back up next week.
Old Oct 31, 2014 | 02:51 AM
  #557
Terrys87's Avatar
I did get some time to get the shop organized again by getting some of the parts back on the truck. I got most of the dash back in. I did a few electrical checks and so far so good. I will eventually get the interior tan but now I want it to look descent, find what parts are missing as I am having to assemble the whole interior from what was in it before.
Getting the headliner in with the window seals is a real pain in the rear. It looks better in person. As of now I have about $100 into the interior. I will have another $100 for carpet and hopefully about $25 for each seat that I will eventually put in. Trucks are easy to make the interiors look great in. To bad this one will be turned to tan but from what was in this truck when I got it, it is 10 times better.
Got most of the fuel system on. I painted the intake manifold to silver. I will do the plenum tonight so as I can try to get it running. I need to get some antifreeze in it.
I got some small guage wire on temporarily for the positive and negative cables to run elelctric test. I will need to get larger gauge wire and get it permanently mounted.
Old Nov 7, 2014 | 11:06 AM
  #558
Terrys87's Avatar
I have been working on my 3rd gen lately and it is taking up the funds for my 85. I have been doing some small detail work on the 85 when I get the chance. Been busy with work and a few other things.
I did pull a goof butt move. My check engine light wasnt working so I looked and there was no bulb in the cluster gauge. After putting in the bulb I still did not have a check engine light, so I started checking some things out and finally I thought I would check the connections on the computer. That was the problem. I had removed the computer and it wasnt even hooked up at all. I actually had the computer in the bed of the truck. Doh!!! Once I installed the computer, Wah laa!! the truck fired up. Wahoo!!! I finally have a great working harness and should have all the options working soon. Still a long ways to go but it is a big hurdle crossed.
Running!!! 12 second video.
Old Nov 7, 2014 | 01:06 PM
  #559
ok i have to laugh at the computer not hooked up
Old Nov 7, 2014 | 06:59 PM
  #560
Yeah I'm not the only one that forgets to hook stuff up lol. Glad you are gaining some ground buddy.
