83txyota 1983 truck crawler build
Old Mar 14, 2014 | 04:56 AM
  #101
gillesdetrail's Avatar
A clunking could be many things, best thing is to get under the truck and check if anything is loose, I haven't done hardcore offroading with mine before the tear down but my friend's samurai with toyota drivetrain just naturally clunks like crazy.
Old Mar 14, 2014 | 04:59 AM
  #102
83TXYOTA's Avatar
Thanks, i can't remember if my old would do the same. I only here it when turning left or right. When driving straight it's not there but I'll look in to the drive shaft bolts and u joints today
Old Mar 14, 2014 | 07:10 AM
  #103
Taco98's Avatar
Check the ujoints. When mine went bad I could shake it with my hands. Also might be worth the piece of mind to pull the birfs out to have a look and maybe pack some more grease in there before you go wheel.
Old Mar 14, 2014 | 07:20 AM
  #104
83TXYOTA's Avatar
Is there not supposed to be any play at all on the driveshaft when moving up\down or side to side. I felt some play but didn't know if it was normal or not.
Old Mar 14, 2014 | 08:23 AM
  #105
Taco98's Avatar
I don't believe there is supposed to be any play in the ujoints it's self. Mine was very obvious that what was moving.
Old Mar 14, 2014 | 10:10 AM
  #106
There isn't supposed to be play, but if the clunks came from a u-joint I don't see why it would only do it when turning left or right. Check the locks and birfs, or bring spares and tools!
Old Mar 14, 2014 | 10:48 AM
  #107
Taco98's Avatar
Agreed. Ujoints would make noise when starting stopping or accelerating. In my experience.
Old Mar 14, 2014 | 11:51 AM
  #108
83TXYOTA's Avatar
Yea i went and drove it again in 4wd and noticed it when just starting to move, I guess yesterday I really only noticed it more when turning since I was turning thru ruts and going up and down hill.
I did pull the front shaft off and saw the center ball on the cv shaft side was loose and confirmed that's where I'm having this nasty popping sound coming from. I looked for parts to rebuild but it's showing 2 different sizes for that center part and don't know which one to get? Know how to figure it out
Old Mar 18, 2014 | 12:30 PM
  #109
83TXYOTA's Avatar
Went out for this first time this weekend and bent my tie rod on the first rock ledge. Anyone ever sleeve there stock tie rod with thicker pipe?
Old Mar 18, 2014 | 12:44 PM
  #110
kawazx636's Avatar
If you aren't going with cross over steering then I would recommend the Sky Manufacturing Heavy Duty Tie Rod.
http://www.sky-manufacturing.com/cgi...y=TOY-HDTR-001
I have one on mine - it's a direct fit.
Old Mar 18, 2014 | 04:29 PM
  #111
83TXYOTA's Avatar
Thanks, i was looking at that tie rod and trail gears but there is a big difference in price. How do u like it
Old Mar 18, 2014 | 08:48 PM
  #112
kawazx636's Avatar
Haven't driven it yet, still building the truck. Looks good though!
Old Mar 19, 2014 | 04:08 AM
  #113
83TXYOTA's Avatar
I was reading thru your build and that thing is awesome, I wish I had the time and patience to go thru mine like that. Looks really good. Did those OME 2" springs lift your truck to much or are they a true 2" spring. I'm thinking of getting some for mine that's probably the highest I want to go with 35s.
Old Mar 19, 2014 | 05:49 AM
  #114
kawazx636's Avatar
They seem to be a little tall, maybe like 3-3.5" instead of 2" but it doesn't have the full weight of the body on it yet and I'm sure it still needs to settle some. I also did 5.5" shackles which are 2" over stock length so that's about 1" of added height. Should be a total lift height of about 3" but I think it may be closer to 4.5" at the moment. It's hard to tell because nobody REALLY knows the actual ride height of these trucks. If the height is a little to high then I may go with shorter shackles. Compared to the old springs on it, which were Rough Country, I can definitely tell that they are a lot softer springs so the ride should be a lot better. But the OME springs could definitely fit 35's.
Old Mar 20, 2014 | 03:54 PM
  #115
83TXYOTA's Avatar
Cool man thanks alot. I'm thinking I'm just going to go all out and 4 link the rear and do my RUF hopefully in the next 2 weeks and go ahead and put get my roll cage built. Your build is awesome, I just went thru ur build page by page and it looks good. I need to learn how to weld. I have never attempted to weld but I seem to learn things easy and fast. We will see how it goes
Old Mar 31, 2014 | 11:40 AM
  #116
83TXYOTA's Avatar
Not much of an update but I got a new house with a 2 car garage so now I can start on my suspension. 57s on the rear and RUF hopefully this weekend.
Old Mar 31, 2014 | 06:30 PM
  #117
rustED's Avatar
Congrats on the new house, I bet you'll get some use out of that garage! Can't wait to see the suspension upgrades, and then some wheeling pics!
Old Apr 14, 2014 | 10:32 PM
  #118
83str8's Avatar
Where you located? Some of the pictures look familiar
6th Gear
19
Dec 10, 2019 07:31 AM
lledwod
Sep 6, 2016 07:33 AM
voiddweller
19
May 2, 2016 09:10 PM
hhsanfor
Jun 30, 2015 06:08 PM
marcusSRG
Jun 27, 2015 07:13 AM
