83txyota 1983 truck crawler build
#101
A clunking could be many things, best thing is to get under the truck and check if anything is loose, I haven't done hardcore offroading with mine before the tear down but my friend's samurai with toyota drivetrain just naturally clunks like crazy.
#102
Thanks, i can't remember if my old would do the same. I only here it when turning left or right. When driving straight it's not there but I'll look in to the drive shaft bolts and u joints today
#106
There isn't supposed to be play, but if the clunks came from a u-joint I don't see why it would only do it when turning left or right. Check the locks and birfs, or bring spares and tools!
#107
Agreed. Ujoints would make noise when starting stopping or accelerating. In my experience.
#108
Yea i went and drove it again in 4wd and noticed it when just starting to move, I guess yesterday I really only noticed it more when turning since I was turning thru ruts and going up and down hill.
I did pull the front shaft off and saw the center ball on the cv shaft side was loose and confirmed that's where I'm having this nasty popping sound coming from. I looked for parts to rebuild but it's showing 2 different sizes for that center part and don't know which one to get? Know how to figure it out
#110
If you aren't going with cross over steering then I would recommend the Sky Manufacturing Heavy Duty Tie Rod.
http://www.sky-manufacturing.com/cgi...y=TOY-HDTR-001
I have one on mine - it's a direct fit.
#113
I was reading thru your build and that thing is awesome, I wish I had the time and patience to go thru mine like that. Looks really good. Did those OME 2" springs lift your truck to much or are they a true 2" spring. I'm thinking of getting some for mine that's probably the highest I want to go with 35s.
#114
They seem to be a little tall, maybe like 3-3.5" instead of 2" but it doesn't have the full weight of the body on it yet and I'm sure it still needs to settle some. I also did 5.5" shackles which are 2" over stock length so that's about 1" of added height. Should be a total lift height of about 3" but I think it may be closer to 4.5" at the moment. It's hard to tell because nobody REALLY knows the actual ride height of these trucks. If the height is a little to high then I may go with shorter shackles. Compared to the old springs on it, which were Rough Country, I can definitely tell that they are a lot softer springs so the ride should be a lot better. But the OME springs could definitely fit 35's.
#115
Cool man thanks alot. I'm thinking I'm just going to go all out and 4 link the rear and do my RUF hopefully in the next 2 weeks and go ahead and put get my roll cage built. Your build is awesome, I just went thru ur build page by page and it looks good. I need to learn how to weld. I have never attempted to weld but I seem to learn things easy and fast. We will see how it goes
6th Gear
19
Dec 10, 2019 07:31 AM
voiddweller
19
May 2, 2016 09:10 PM
