Diesel Swaps Diesel engines
Project: 86 p/u sas/om617 diesel swap
Old Apr 22, 2013 | 10:19 AM
  #361
pyrojoe22's Avatar
Got the engine timed to 27 BTDC. EGT's are down a little bit, Water temp is up to 189 from 180. I can FINALLY cruise above 3000 rpm. I'm going to still look into the intercooler, though. My egt's are still unacceptable. Hoping for a smidge more power. The advancement didn't give me a huge power increase, but it's definitely noticeable.
Also, my Marlin tranny is making noises already. I haven't even used 5th gear for fear of it blowing up. I hope to God this thing never blows up.
Old Apr 22, 2013 | 01:47 PM
  #362
Transplanter's Avatar
You're welcome, glad I could help you out.
Old Apr 22, 2013 | 02:06 PM
  #363
pyrojoe22's Avatar
Actually, it was PowerstrokeJoe that spent 40 minutes on the phone with me troubleshooting and lent me his drip tube timer.
Thanks again Joe!
Joe and I are planning on dynoing our trucks sometime soon to see how they compare. His felt way faster to me.
Old Apr 22, 2013 | 02:26 PM
  #364
And how many times did I tell you to advance your timing to lower your egts??
Old Apr 24, 2013 | 05:58 PM
  #365
yodacrawler89's Avatar
hows the vibration on that baby at idle ? fired mine up tonight and it will vibrate your dick off at idle do you get any bad vibes out of yours ?
Old Apr 25, 2013 | 06:00 AM
  #366
pyrojoe22's Avatar
Originally Posted by yodacrawler89
hows the vibration on that baby at idle ? fired mine up tonight and it will vibrate at idle do you get any bad vibes out of yours ?
With solid motor mounts and transfer case mount it shouldn't vibrate. I'm in the same boat, though, when it comes to having an increase in time to return to idle once you adjust the idle up. My idle was at 500, and it would rocket back down to 500 when I let off the throttle. I set it to 750-800 and it took forEVER to come back down. Now it's at 600-650 and it's bearable. I'm sure Roy at peachparts knows. I just haven't had time this week to ask anyone. Let us know if you figure it out!
Old Apr 25, 2013 | 09:28 AM
  #367
pyrojoe22's Avatar
Originally Posted by 89lc
... I had a wrx intercooler I was going to mount over the engine.
I've been bidding on them on ebay this past week. Trying to get one for around $25 to experiment with. Do you know by any chance if you can cap the inlet holes and make a new inlet on the same side as the outlet? Without being able to do that, I highly doubt I'll have the height clearance to fit one of them.
Old Apr 27, 2013 | 08:04 PM
  #368
hey pyro i read that you just advanced your pump timing to 27 deg ? does it run any better power wise and how is the injector nailing louder or quieter ? smooth engine out at all or does it run rougher . oh i figured out how to fix the idle problem i adjusted my idle all the way down so it drops fast then i adjusted my throttle cable to my desired idle works great just dont have the emergency shut off anymore but that why i have a key for lol hopefully
Old Apr 28, 2013 | 06:55 PM
  #369
pyrojoe22's Avatar
Night and day difference for the better! Better mileage and lots more power. Lower EGT's. Definitely worth doing.
Old Apr 29, 2013 | 06:15 AM
  #370
ravenr106's Avatar
hey guys I ordered the midline kit at tdswaps a couple months ago and when I went to bolt the adapter plate to the engine the bolts were to short. Did anyone else have this problem?
Old Apr 29, 2013 | 11:00 AM
  #371
pyrojoe22's Avatar
I used 4x4labs kit
Old Apr 29, 2013 | 12:25 PM
  #372
ravenr106's Avatar
I tried calling 4x4 labs several times but no one would be call me back.
Old Apr 29, 2013 | 12:27 PM
  #373
pyrojoe22's Avatar
I don't know what he spends his time doing, but he definitely needs to improve his communication skill. If you stay persistent, he will answer or call back eventually and get you taken care of.
Old Apr 30, 2013 | 09:04 PM
  #374
digger_cokley1's Avatar
om617 swap ina 4 runner
? m617 for you hardcore swappers. im putting a om617 in a 94 four runner just wondering if i need any vacuum stuff or special parts to save before getting rid of the six leaker. ill post some pics of my runner so you guys can pick it apart. 3 in sas trail gear swap with 33x14.5 boggers with weld super single 13 wides. . o and sorry for bustin in on the thread. been doin a lot of work on my motor and talkin with alot of people about performance on the om617. a guy (dieselmakin from germany) seems that i am going to get an m pump and send it over to get hopped up through him. he does amazing work the the guy is a beast with pumps.
Old Apr 30, 2013 | 09:39 PM
  #375
the four runner sas swap
Attached Thumbnails Project: 86 p/u sas/om617 diesel swap-img_20130306_134704.jpg   Project: 86 p/u sas/om617 diesel swap-img_20130322_185832.jpg   Project: 86 p/u sas/om617 diesel swap-part_1367385289539.jpeg
Old Apr 30, 2013 | 09:43 PM
  #376
random pics
Attached Thumbnails Project: 86 p/u sas/om617 diesel swap-img_20130307_181820.jpg   Project: 86 p/u sas/om617 diesel swap-img_20130427_162714.jpg
Old May 1, 2013 | 09:03 PM
  #377
PowerstrokeJoe's Avatar
There is a list of everything you will need near the end of my thread. The only vacuum crap you need is the brakes and shut off.
Old May 2, 2013 | 10:59 PM
  #378
thanks powerstroke just wanted to double check before i got rid of stuff i needed. going to pull the motor this weekend im pumped. should be fun. i put some pics pics up on my build thread ill start.
Old May 4, 2013 | 07:11 PM
  #379
pyrojoe22's Avatar
It really depends on what you want to use. I used the stock gauges for a while, but that was a waste of time and effort. The stock gauges are not accurate enough and not worth using. I also ditched the yota alternator for a GM CS130 105 amp. Keep your starter and flywheel.
Old May 5, 2013 | 08:56 PM
  #380
awesome do you notice a big difference in the alternator? ill probably use the stock gages for now til i finish all the loose ends than do all the after market stuff my goal is to have this project done by august we will see.
