All Other Toyota Swaps I4, I6, Lexus V8
Live4soccer7's 84runner 1UZ Swap
Old Apr 29, 2014 | 09:41 AM
  #101
live4soccer7's Avatar
Originally Posted by Bingle
I can't argue with any of the above GM options, but with well over 500k mi on the truck and had 417k on the original engine, there's a reason I want to stay all toyota drivetrain. I swear that the harder you beat on a toyota, the better they perform.
Also my frist gen truck weighs even less than your runner, and cirtainly less than second gen runners, that people seem really happy with 1UZ engines in. Compared to the 22r, the 1UZ is a monster.
Agreed, they are great and possibly even better. My 4runner should weigh in at around 4k, which is actually close to what the lexus LS400 weighs in at (~3800). The lexus is really aerodynamic for a luxury sedan as well.
Again, I don't think you can go wrong with either direction for a swap. Undoubtedly, there have been times where I thought I should have chosen a different option, but when I search more on it I always come back to the UZ. If I were to do any other swap, it would be LSx.
Old Apr 30, 2014 | 03:33 PM
  #102
Just a little update:
The fuse/relay box is somewhat mounts. It need to be refined a little, but it is in place and holding the contents.
With the lid, yes the hood closes:
I have gone around and connected all the harness grounds to the body and then the main battery cable ground to the frame.
According to the FSM the battery + connection goes to the fusible links seen toward the very top of the first photo on the fuse box. I have created a little mini power harness to go directly from the battery to those for testing. That should get me power in my harness in most places. I have also connected the opening circuit relay that is attached to the ECU (just plugged in it hoping it would help). I've got nothing at the moment, so I must be missing something. Not even the sound of a single relay clicking.
It was quite the disappointment, but I need to get my multi-meter and see what the heck is happening. Unfortunately, it is not with me at the truck and I won't be able to further test without it.
Seems pretty straight forward, but something I'm not seeing.
Old Apr 30, 2014 | 04:48 PM
  #103
It must have been a ground or something along those lines. Didn't do much and I now have power:
I should be able to start splicing some of the toyota connectors on to the lexus harness tomorrow. It will finally and slowly begin to revive, starting with the headlights. It runs without the charger on it (now I know my battery is good).
Old May 1, 2014 | 07:46 PM
  #104
This is pretty straight forward. The headlights, front marker lights, and front blinkers have all been this way.
Toyota likes white/black for ground.
The headlights, match the two wires that are the exact same in color and then the last of the three wires splice together. I did look all this up in the wiring diagrams before doing so. The headlights work.
The front blinkers and side markers are the same. There is one wire that matches (ground: white/black). Solder that and then simply solder the other wire that is left to splice in these to components. Just one photo since they are the same on both sides and for the blinkers/sidemarkers.
This is for the rear running lights. From the connectors that come in by the step seal/tread/trim on the toyota (whatever you want to call it), there is a couple white/black wires. I tied these together and then tied them in to the ground points by the kick panels on both sides. This should hopefully ground anything that needs it from the rear of the truck if it is not already grounded. Then there is the green/orange wire that controls the rear running lights on the lexus harness. Solder that to the green wire on the toyota harness that comes from the rear of the truck. You have to do this on both sides of the truck. The red wire you see is a jumper from the driver side to the passenger side of the vehicle. The green/orange wire does not route to the passenger side otherwise.
And a sad excuse of a solder job for the passenger side jumper wire. You should connect to the pure green wire for the runnning lights, not the green/white (i had it mixed up).
I did do the backup/reverse lights too, but must have forgotten the photo. This is a red/black wire (lexus) that goes to the same place on the toyota harness as the rear running lights and connects to a red/blue wire.
Red/black Lexus --> Red/blue toyota (have not tested this as I need to install the switch still).
And a couple photos to show the progress:
Old May 2, 2014 | 09:24 PM
  #105
I have wired up the rear brake lights now. That was simple. Green/white on the lex harness to green white on the toyota harness. Green white on the lex harness is accessible on both driver and pass side of the harness, so it was easy.
I replaced the brake switch on the toyota with the one from the lex. It was a direct replacement. I had to extend the plug on the lexus harness to reach the location of the switch. That was very easy to do.
The rear blinkers have been hooked up and the hazards work on all corners.
I used the lexus horns, so that was plug and play. I may have to extend the wires for final placement, but they worked first try.
The reverse lights are hooked up too. red/black on the lexus harness to red/blue on the toyota harness. I have to wire in the switch to test it. I forgot the switch today, so I will try and do that tomorrow. Once I get the reverse lights hooked up then I get to move in to the interior and work on hooking up the interior ancillaries.
Old May 4, 2014 | 05:01 PM
  #106
87-SR5's Avatar
Loosing comunication with the rear O2's is fine.
It will not go into limp mode or anything like that. It won't pass emisions, but I don't have to worry about that kind of thing.
Old May 5, 2014 | 07:56 AM
  #107
Great. Thanks for the info. I don't have to do emissions either.
Old May 7, 2014 | 09:39 PM
  #108
Just a quick update.
I have the interior lights working with the exception of one or two switched lights in the back.
All of the exterior lights are fully functional on the truck.
The wiper motor does work perfectly with the lexus system and steering column.
I pretty much just have to wire up the wiper motor, wiper fluid motor, and the tailgate stuff and all the wiring will be done. Once I get those finished up then I can tidy up the harness for the last time and seal it up with the braided split loom.
I do have to sort the clutch/flywheel portion (have all the parts though) of it and tidy up the last couple things on the engine as well. I'm still in need of an EGR tube. Does anyone have one that's not cracked that they'd like to ship me?? Just PM me and we can work out the details if anyone has extras laying around.
Old May 13, 2014 | 10:57 PM
  #109
The wiring is done now. Everything in, on, and around the truck works electrically with the lexus harness. I'm working on wrapping the harness now. The only real issues I had with any of it was working with things on the truck that didn't work in the first place, so the trouble shooting was compounded because of this. I would say that it was generally very easy to wire it all though. It did take a good amount of time, but well worth it. The lights in the truck even dim down when you shut the door (compliments of the Lexus ICU).
I do have a question for those that started off with a 22r/e or may have knowledge on this topic. I know the pumps are internal tank and I was speaking with someone regarding fuel pump options and they had stated that the 3.0/3.4's are internal pumps and the lexus pump is nearly a direct bolt in for these tanks. If this is the case, then is there any chance a 3.0/3.4 tank pretty much bolts in place of the 22r tank?
I can pick up a tank over here nearly any day of the week at a yard, so it would definitely be worth looking in to for the ease of installation of the fuel pump setup.
Old May 22, 2014 | 11:48 AM
  #110
Another update. Not much as I'm trying to finish up the loom, but ran out of the split loom stuff and had to order more. I should hopefully have it saturday so I can finish over the weekend. If I can then I'll shoot a few photos of all the wiring.
The bracket that was built to hold the lexus fuse box in the engine bay. I took the old power steering fluid reservoir and welded the base together (mounting points on the bracket) and then cut the tank off and then welded another piece on for the fuse box to bolt to. The last piece is just there for stability of the whole thing. I also welded the nuts to the back side of the mounting side so you can easily bolt the fuse box on to the bracket after bolting the bracket to the truck.
Yes, the bracket may be a little overkill, but it was what metal I had at the time that would work. It is now very sturdy, where before it was sloppily bolted on and unstable simply for fitment purposes and wiring.
Old May 29, 2014 | 12:10 PM
  #111
Anyone know what the interchangeability for gas tanks are in the 1st gen 4runners? I have an 84 4runner with a 22r. I want to get one from a 22re or maybe even the v6 with the in tank fuel pump. Which ones will be a direct replacement for my 84 4runner?
Models?
Years?
Truck/4runner?
2WD/4WD?
Engine?
Anything would help in finding one, if you know about the interchangeability on them.
Old Jun 6, 2014 | 09:37 AM
  #112
I began putting the dash back together yesterday. As much as possible anyways. I still have to figure out the cluster fitment and steering wheel garnish.
Anyone that has put a manual behind the UZ, are you using the 'spacer' plates that were originally on there with the auto tranny?
Old Jun 7, 2014 | 11:36 PM
  #113
As promised, some wiring and dash pictures of the progress over the last month or so.
Engine bay. pass side.
This will be cleaned up a little. The red wires you see are temporarily there for testing the electrical system without the engine harness in place.
Just a pic of the driver side harness that goes from the cab to the engine bay. I still need to secure it in place, obviously.
A shot of the lexus wiring and lexus fuse box behind the kick panel. It is a snug fit, but you can coax it to fit correctly. It is being held in by zip ties, which actually work extremely well and secure it very well (2 of them)
Just an under the dash shot. A few stragglers that need to be cleaned up, but mostly tucked away.
I need to clean the floor boards, but you can see the ECU related part of the harness and the part that attaches to the engine side of the harness that will come through the firewall behind the glove box. I need to tuck those behind the dash and route the appropriate plugs in to the glove box where the ECU is located right now.
A nearly perfect fit.
A shot of some wiring behind the radio area.
Blinker/marker plugs:
Passenger side loom from cab to engine bay, I drilled a new wire loom hole the same size as the ones already in the engine bay so I can use the same grommets that were already in use.
I ran a large portion of the wires that came from the fuse box behind the driver side kick panel over the heater core area behind the vents. The original yota harness was actually ran this way as well.
A shot of the lexus steering wheel with the garnish and appropriate dash pieces in place. It surprisingly fits very well and I had to do minimal trimming to the lexus steering column plastics and toyota dash to get full movement out of the electric steering column.
Another shot from the underside of the steering wheel. You can see where I made the cuts, but not very noticeable. The pass. side of the steering wheel required a little more cutting because of where the key/ignition placement is, but I must have forgotten to photo that. Still not bad though considering a completely different setup is in the truck.
Things left to do now:
Get the tranny adapted/hooked up (have all parts, just need to modify slave cylinder mount and put together)
Finish up a couple things on the motor itself (waiting on some parts from sewell lexus)
Mount motor/tranny in truck
Fuel (getting 4runner v6 or 22re tank, using lexus pump)
Cooling (still working on details)
Exhaust - will likely just have a shop do it after I get the headers all fixed/fitted, don't have the tools and not a fan of working on exhaust. It is relatively inexpensive and worth it IMO.
Speedo? Lexus cluster with RF1A transfer?? (Ideas?)
Adapt Power steering
While quite a few things to do still, I feel the major part is out of the way, wiring and prep work.
For anyone that is new the thread: I took the entire lexus dash/engine harness and replaced the toyota dash/engine bay harness with it. Every electrical aspect on the toyota has been hooked up to work with the new harness and electrical system. Everything has been tested and works great and as it would have originally. It was a lot of work, but I think will be worth it for me in the end, considering I have picked up several new and useful features. It has also made other ammenities that came with the lexus a plug and play setup (cruise control is one example of many). I chose to do it this way because the truck electrical system was minimal vs something newer (made it feasible) and the truck will be an all around rig that I wanted to keep the luxuries functional and add some as well.
Old Jun 8, 2014 | 05:37 PM
  #114
87-SR5's Avatar
This might work!
https://www.trail-gear.com/TG/Speedo...x#.U5UPmW0yk1k
Old Jun 8, 2014 | 08:27 PM
  #115
I have seen that one before and I think marlin also sells one too. I just wonder if the signal is the same between the lexus speedo and that sensor.
Old Jun 9, 2014 | 06:26 AM
  #116
Bingle's Avatar
Looking good Nick! Can't wait to see that beast out on the road.
Old Jun 9, 2014 | 07:10 AM
  #117
You and me both! Thanks.
I'm pretty much just waiting on some parts for the engine to come in. I'm mostly at a stand still until then. Also crossing my fingers that an LS400 shows up at Pull and Save. There was one at one of the yards at all times last year (probably 4-5 throughout the year), but now nothing and I need some parts I was not aware needed replacing until very recently
Also need a damn 4runner gas tank as well and I saw a couple 4runners over the last year and now there isn't one there. The tanks are always left on them as well. Can't find on on CL either.
Old Jun 9, 2014 | 02:28 PM
  #118
Since I am back to waiting on parts right now, I figured it would be a good time to work on how to hook up the power steering. What hoses did you guys get to connect the steering box to the lexus pump/reservoir. I've got the LS400 pump/reservoir, so it sits nicely on the side of the engine.
If you've got pics of your PS setup, feel free to post up.
Old Jun 9, 2014 | 08:45 PM
  #119
I would assume that these hard lines will be in the way since the engine pretty much needs to be hugging the wall. I'm trying to find things to do while I wait for parts to come in the mail. Those that did this in the 84-88/89 trucks or had these lines in the same location, what did you do?
Old Jun 9, 2014 | 09:23 PM
  #120
Anyone know the specs for the clutch slave cylinder bolts that go in to the bell housing so I can borrow a tap from a friend to modify the mount?
