All Other Toyota Swaps I4, I6, Lexus V8
1uz-fe into 93 pickup with R150f and IFS
Old Aug 7, 2011 | 10:32 AM
  #81
4.0 Pickup's Avatar
True James. Not fast like a 300zx. I got a new time for the year with the zx. 12.939
You're sure you don't want to trade? And she's now in...
Flat black!!
Now I don't know if the black will make me go faster...
Old Aug 7, 2011 | 11:19 AM
  #82
Yota 3.0's Avatar
Looks sic Dave! I always loved the flat black look. I also see a couple of nice 240's in the back.
Hahaha no trades! Thanks anyway haha
Old Aug 7, 2011 | 06:24 PM
  #83
4.0 Pickup's Avatar
Thanks for the comments bro
I appreciate it.
Old Sep 2, 2011 | 03:02 AM
  #84
BerHntr's Avatar
Quick question, you said you didn't use the input shaft extension and everything worked out fine? I plan on using the ks racing bh also. I've read that the 96+ r150's have a 1" longer input shaft...so would I be correct in assuming that a 96+ would eliminate the need for the extension altogether?
Old Sep 2, 2011 | 05:11 AM
  #85
4.0 Pickup's Avatar
Nope, I didnt use any input shaft extension. KS racing forgot to put it in my box i guess. They also forgot to trow in every other thing like the pilot bearing kit and etc...
After having the flywheel machined, I installed everyting and looked trough the clutch fork hole. The input shaft was in the pilot bearing. I dont know by how much but...
I didnt get any problem since. First sign would have been vibration or oil leak from the input shaft. But, non of these signs.
But hey, maybe I have a 96+ trans but I dont think so.
Old Feb 15, 2012 | 09:22 PM
  #86
zukijames's Avatar
heeeelp me im getting ready to throw my swap in the garbage!
Old Feb 16, 2012 | 12:56 PM
  #87
4.0 Pickup's Avatar
You live way to far !! Ask a neighbour...lol
What's wrong? If its the wiring, i might have forgot a lots of stuff.
Old Feb 16, 2012 | 01:00 PM
  #88
SHAGGY21's Avatar
I p.m'ed him as I will be in saltlake at the end of next month. Maybe I could help him when im out there. So how is yours running.
Old Feb 16, 2012 | 01:41 PM
  #89
4.0 Pickup's Avatar
You can post questions here Zuki. No problem.
That way, we could share answer's with the world !
Mine's is still running fine. I got exhaust leaks from the manifold/downpipe that are getting worst from day to day but i can live with that for the moment.
Apart from that, my truck body is getting soft. I will have to do something about it if i want to keep it for an other 5-6 years. Also, i spoted a tiny crack in the frame will changing the rear 3rd member. Yes i blew the rear end. I bought a 4cyl one at the scrap yard for 60$ and got it welded from a friend
I now love more my truck but the clutch dosent like left foot kicks is 2nd on tarmac.
Im thinking about sas-ing it. Im also thinking about a truggy. I would love to make a round tube/flat bed/light bars/streeable rear bed. Probly shorten to.
Time will see.
Here's a few picture while im at it.
I Made a pair of these. Took a while...
Got the Z wheel's painted subie blue and added spacers ( cheap way to change the look)
Thats my mic, 3 of my basses and the newest amp that bring the ViIIiBbe's to the band
A day in the wood
broke the idler that that day
Thats my truck winching my friend 86 pickup/1.9 Tdi volks on a trailler cause he bented valves.
The 4cyl 4.56 getting hacked
And here's....Well, you know
Old Feb 18, 2012 | 03:27 PM
  #90
SHAGGY21's Avatar
yeah my left manifold to y-pipe gasket is leaking. i need to fix it but i just keep getting mor things to put om her and the exhaust gets put on the back burner.
Old Feb 19, 2012 | 07:06 AM
  #91
4.0 Pickup's Avatar
My gasket leaks are caused by the upper control arms hitting the manifold upon flexing. To solve this problem, I will sadly need to Sas it
Plus, my ball joint spacers with +0'' front shock caused one front shock to pop out. I ordered some +3" last friday. That will solve one problem this week.
I forgot to add these pictures in my lastest update.
I only used it a couple times yet.
Old Aug 5, 2012 | 10:47 PM
  #92
x2468's Avatar
WOW! where in quebec are you? I have a lot of family up there. Next time i'm up i want to go see your truck in person! Awesome.
BTW, would aftermarket control arms fix your clearance issue?
Old Aug 7, 2012 | 06:42 PM
  #93
4.0 Pickup's Avatar
Im in Gatineau, juste beside Ottawa.
I didnt think about aftermarket control arms. Tho, SAS'in it will solve the issue. Or, some mods on the headers with skills i didnt have in the past.
Old Oct 10, 2012 | 12:40 AM
  #94
UVRUGBY's Avatar
did you ever get your speedo figured out? try using a radar gun to see what your actual speed is? and are the 4.58 gears giving the power you need to roll, or would the 4.10 gears do the trick? did you ever get around to getting a total amount for how much the swap ended up coming out to? Did you use the stock oil pan?
Im getting ready to do this swap into my '90 PU and basically going the same route you did, staying IFS picking up a whole car to part it out, and keeping the stock r150 tranny.
Thanks for the info.
Old Oct 17, 2012 | 05:08 AM
  #95
4.0 Pickup's Avatar
Speedo is still the same. About 5kph off. I used my phone gps to figure it out. A top speed of 175kph as been achived...lol
I got plenty of power with the 4.56 on the road. 4.10 would be worst on the speedo. If the truck was dedicated for off road only, at least 4.88 will be a solid choice.
This swap probly cost around 2000$ depending on ressources.
And yes i used the stock oil pan but, you got to know I have a 3" body lift and that helped to get my engine sitting higher.
sandyota
Feb 4, 2021 11:16 AM
icentropy
Sep 16, 2020 02:47 PM
XtraCab
Apr 12, 2020 05:25 AM
Sep 4, 2015 09:27 AM
