irab88 adds another liter: 22R-EC to 5VZ-FE
Old Jul 22, 2014 | 04:52 AM
  #161
irab88's Avatar
i'm trying to just pull out the engine-support plugs, but everything seems to be connected to everything else. i'll have to go about this wire-by-wire for the ~4 plugs i need, and find where to splice them into the 93's circuits (brake switch, ignition switch, clutch cancel, 4wd, vss)
i also got my "new" crossmember and top bellhousing plug yesterday
Old Jul 22, 2014 | 05:20 AM
  #162
irab88's Avatar
crossmember from a v6, so hopefully things will line up
Old Jul 22, 2014 | 05:28 AM
  #163
RBX's Avatar
RBX
Nice progress, be happy you have a vehicle that has a vetted wire diagram to go by(the 22re of the 90's).
the 88 3vze electrical wire diagram on the other hand, is unique to all other model years for some reason.
Old Jul 22, 2014 | 06:20 AM
  #164
dntsdad's Avatar
Hey Ian or anyone else.
1st gen diagrams into the google drive would be great!! Those things seem to be scarce.
Old Jul 22, 2014 | 04:23 PM
  #165
irab88's Avatar
got the stiffening brackets and flywheel cover on this evening. i had to make my own plate, as the new one was basically the same as the old one with larger bolt holes. foo.
the cookie sheet was too big for my oven, so sacrificial sheet metal it is!
i didn't bother trimming it, don't see a need right now
and with the brackets
and i got the top plug in. "plug" is a loose term, it's more of a vent
Old Jul 28, 2014 | 06:56 AM
  #166
irab88's Avatar
yotatech seems to be blocked at the moment, so i'll try posting this from my phone
got a lot of little things done this past weekend, including vacuum routing, cleaning up my custom rat's nest wiring, figuring out the new engine's wiring, lengthening a few cables, installing and bleeding a new clutch line, and a few other small things.
first up, vacuum wiring
since i sold off my old engine, i needed to find another small-line vsv. i used the blue one from the add system on the 4runner. i hope it works, and if not, i have the original one (that i'll need to adapt to the right size)
everything fits nicely in the corner here
and the lines i extended
vacuum line for the brake booster. i've used that 3/8 fuel line for so much stuff on this build.
then i pulled out all the custom wiring. it was easy to add new things to my setup, but there was no cable organization at all. back to the drawing board.
since the old clutch line was in the way of my crossover pipe, i got a new braided line from ebay. the pedal is much firmer now
my slave cylindar was clogged with some dirt. after cleaning it out, the inside is like new. probably the first time it's been serviced since new
the trouble area
finally, since the threat of storms loomed over all day, i worked on the wiring harness. i got it down to this: ecu plug, obdii plug, and 2 plugs that come from the engine, but i have no idea what they're for (gauge cluster, maybe?)
Old Jul 28, 2014 | 07:07 AM
  #167
RBX's Avatar
RBX
awesome work, lots of little stuff really eats into the project time line. Not to mention the Florida weather we are having.
Old Jul 28, 2014 | 04:00 PM
  #168
irab88's Avatar
yeah, no kidding! i sat inside working on the wiring harness yesterday, avoiding the weather.
today marked another major milestone: i got the electronics working! on the first try, too!
basically, the ecu, hooked up to the engine (sensors), hooked up to 12v, and my obd2 scanner plugged in. the software was able to read about half of the pid's which makes sense (lots of things either not plugged in yet or reading zero, like tach and speed)
also put the air intake in. i'll probably keep the intake tube and put a cone filter on until i get this thing up and running
i didn't get any pictures, but i also secured the new clutch line out of the way
and the last thing i did before the mosquitoes got bad was drill out the old studs from the downpipe flange. i'm just going to use bolts and nuts for the exhaust to avoid trying to re-thread everything.
the last things to do, in no particular order:
-finish the wiring
-remake the driveshafts
-install exhaust
-install heat shield on firewall
-timing belt
-radiator
-fluids
-battery wiring
Old Jul 28, 2014 | 05:41 PM
  #169
dntsdad's Avatar
lookin good
put a check valve on the brake booster line
Old Jul 28, 2014 | 07:17 PM
  #170
irab88's Avatar
thanks. I wasn't sure about it, as I didn't remember taking one off. but then I looked at my pictures and saw it's "built into" the 3.4 booster. is it something I can buy separate, or can I use the one off the 4runner?
Old Aug 22, 2014 | 10:49 AM
  #171
JBurt's Avatar
How has August been for engine swaps? Almost done?
Old Aug 22, 2014 | 12:45 PM
  #172
irab88's Avatar
irab88 adds another liter: 22R-EC to 5VZ-FE-x1gc8yf.gif
between a family reunion out of state, a convention, and multiple 60-70 hour work weeks, the most I've gotten done is installing the check valve
Old Aug 22, 2014 | 02:15 PM
  #173
dntsdad's Avatar
If your booster has the built in one, that's all you'll need. No need for another one. I couldn't see it from the initial pictures.
Damn 84 degree intake air temp??! It doesn't get that cool around here unless it's 4am this time of year. Must be nice. I think it's like 1....0....bazillion today. Ready for fall!
Old Sep 4, 2014 | 05:15 AM
  #174
irab88's Avatar
3/8" check valve, ebay, $5
i ordered some parts to "finish" off the exhaust. i'll start working on the timing belt and more wiring next week when it gets cooler.
my hope is to get this thing started by the end of october. most of my weekends now will be spent building model railroad bridges with my dad. here's one we built last year; i hope to get two more done by thanksgiving weekend.
(size reference: the bridge itself is ~6 feet long)
Old Sep 4, 2014 | 05:40 AM
  #175
RBX's Avatar
RBX
What was the check valve for?
Old Sep 4, 2014 | 05:44 AM
  #176
irab88's Avatar
jason said i needed one, so i put one in
Old Sep 5, 2014 | 11:41 AM
  #177
"G"'s Avatar
"G"
Why wouldn't you replace the slave with a new one when you had the engine out? It's a $20 part. In order to save the aggravation of replacing later.
Old Sep 5, 2014 | 12:44 PM
  #178
irab88's Avatar
because it's $20 i didn't want to spend
naw, but seriously. it works now, and it's easy enough to get to if i need to replace it in the future. i also didn't want to spend another hour to drive out, get the part, drive back, remove, and install. time is more important than money on this project. i've been away for more than 3 months since i started this project back in march, and the holidays (basically now until jan 2) show no sign of slowing. sigh.
Old Sep 11, 2014 | 08:52 AM
  #179
3mph Toy's Avatar
Following this forum for sure! Nice job Ian!!
Old Sep 11, 2014 | 09:05 AM
  #180
irab88's Avatar
thanks pete!
so, some less-than-extatic news; i will not be working on the truck on the weekends, and my weekly building will slow waaaaay down until the end of december. i looked at my calendar and saw that i already have more than half my weekends booked, and i still have to decide on non-toyota things for the other half. everything is fine in my life right now, i just need to take care of other things. i miss driving my truck sooooo much, but i know i won't do a good job if i just half-ass it.
post for the next 3½ months will be sparse
