irab88 adds another liter: 22R-EC to 5VZ-FE
Old Jun 2, 2014 | 06:55 AM
  #141
rattlewagon's Avatar
Quality work as always!
Old Jun 2, 2014 | 03:03 PM
  #142
LolaL's Avatar
glad we could help can't wait to see this thing rolling.
Old Jun 2, 2014 | 07:02 PM
  #143
RBX's Avatar
RBX
Dam, someone else from Baltimore.
Sorry I couldn't make it. I need to get your brackets in the mail.
Old Jun 3, 2014 | 04:04 AM
  #144
irab88's Avatar
thanks!
though, if you knew what i'm capable of, you'd know i'm being fairly lazy with this project, haha!
nor can i. it's awesome to have all the heavy lifting done!
someone else to caravan up to rausch creek with!
it's all good. brian hasn't shipped the cover plate yet, and i have some parts i'm sending him today. toyota parts never get thrown away; they just hitch rides on other toyota trucks
Old Jun 3, 2014 | 04:09 AM
  #145
RBX's Avatar
RBX
Originally Posted by irab88
thanks!
snip...
Tru Dat.
I started cleaning your brackets last night, they will ship soon.
Old Jun 23, 2014 | 06:32 PM
  #146
irab88's Avatar
The internet was down today, so a few pics sometime tomorrow.
I got most of the body lift installed. The kit from 4crawler is complete, but the bumper spacers have holes that don't line up, or let you use the valance support. Also, one of the tabs he welded on a nut fell off. I'll be putting on a different bumper sometime in the near future, but it will all work out.
Old Jun 24, 2014 | 05:42 AM
  #147
irab88's Avatar
face removed
i had trouble getting the old 14mm bolts out that hold the large body mounts in place, so i just left them in for now. once i get everything set up, then i'll get back to them
i got everything done except the radiator brackets. i'll put those on when i get to the engine work again. the body lift is very easy to install, and the blocks 4crawler makes are very high quality. i'm going to wait on doing the bed until everything else is done with this swap.
now the engine sits lower under the hood
and the hood closes
i'll still add vents for getting rid of the added heat
it doesn't look familiar anymore...
and for anyone wondering, this is a 2 inch body lift. just the right amount of lift. if i hadn't used the chilkat motor mount plates, the engine would have sit about 0.5" lower, needing only a 1.5" body lift
Old Jul 6, 2014 | 09:08 AM
  #148
irab88's Avatar
Did a bunch of little things this weekend. the weather has been great, so fuel lines, power steering lines, ignitor, (temporary) crossmember, and shift lever bases got done.
fuel filter to engine
from tank to filter
both high and low pressure steering lines
shift lever bases. huge opening needed, but only a bit farther back than stock. this should let me retain the center console
a little too low, but that's with the lowered crossmember from before the body lift. i'll end up making my own soon
starter in place. the bottom mounting hole on the starter (not bellhousing) needs to be drilled out. then a bolt will fit in nicely
the plate and stiffening brackets. the brackets bolt right up, but the plate has some issues. the holes are too small (meant for m8, not m10). and the holes on the left side don't line up with the bracket. i guess the auto bellhousing is a bit different (auto plate, manual brackets)
and lastly, the ignitor. i bent the tabs a hair, and there were two bolt holes that lined up perfectly.
fuel line size: 5/16
power steering line size (both high and low): 3/8
next issue i ran into was the clutch line. it's damn close to the exhaust. thank goodness i'm not running the exhaust down the passenger side
Old Jul 6, 2014 | 10:16 PM
  #149
RBX's Avatar
RBX
Nice progress.
I found my auto inspection plate, and figured I would use it on the manual since I'm missing mine. But it's not even close to fitting the R150 bellhouse.
Old Jul 7, 2014 | 04:19 AM
  #150
irab88's Avatar
yep. this plate is from brian's auto when he did his trans swap. so cardboard template it is! haha
Old Jul 7, 2014 | 09:42 AM
  #151
irab88's Avatar
for my info
https://www.yotatech.com/forums/f160...l#post50685251
Old Jul 17, 2014 | 06:45 PM
  #152
irab88's Avatar
did a few small things this evening
just a bit of dust
Old Jul 18, 2014 | 04:26 AM
  #153
RBX's Avatar
RBX
Nice. So the ecu will sit in the same location as the old?
Old Jul 18, 2014 | 04:46 AM
  #154
irab88's Avatar
i'll try to make it work. i know some people have had fitment issues.
i might also tuck it behind the glove box, in case of high water
Old Jul 18, 2014 | 08:44 AM
  #155
ChefYota4x4's Avatar
Freaking awesome work, man! Definitely wish I had gone for an upgrade motor before doing another 2.4... But it's been pretty good to me so I will just have to live with it for a while. Lol.... Great job so far, Ian!
Old Jul 19, 2014 | 03:51 PM
  #156
irab88's Avatar
built the different style o2 sensor emulator. this one uses a 555 timer to output the same signal as the rear o2 sensor.
i went ahead and ordered the factory cover plate
part numbers for both the seal and plate
installed the throttle cable from the 3.4. it fits a lot better
Old Jul 20, 2014 | 08:55 PM
  #157
SacRunner's Avatar
There's a seal for the flywheel cover plate?!?! Learn something new everyday.
Good job on the swap so far
Old Jul 21, 2014 | 04:11 AM
  #158
irab88's Avatar
thanks
yep, there's a seal. and both the plate and seal were cheap enough that i went ahead and ordered them new instead of making my own. i'll install them sometime this week, as i'll be finishing up the crossmember
Old Jul 21, 2014 | 08:38 AM
  #159
irab88's Avatar
...and now
the fun begins...
Old Jul 21, 2014 | 01:27 PM
  #160
Woohoooo! Lol
