NEED HELP 22RE to 22R
hey everyone this is my delema i,ve searched everywhere and everyone says stay EFI, i dont have that option so dont say it,
1986 toyota p/u 22r carberated 5 speed 4x4
took the 22r out and am putting it in to a 1987 toyota 4runner 22re EFI 5 speed 4x4 that was efi
both trucks have wire harness
i need to know how the hell i get the 22r to run in the 22re efi truck, the wire harness are different i already tried swapping them, what wires need to be hooked up for 22r to run and run well please any and all in put is need and and greatly appercitated
basically how do i wire up a 22r in to a 22re enigne bay
Hey Delema I'm having the same problem but i'm trying to put a efi into my 22r. All harnesses match but one. None of the color codes match except the three a main power sources. On a 22r you don't need the ecu anymore so the only plugs you need is the two leading leading from the fuse box and instrument cluster to the passenger kick panel. Are those the two your saying are different?
I have done this on my '92 truck, except I didn't want to hack into a perfect RE harness. So I built my own and everything is working just fine.
I see this an old thread, if you need assistance, reply and I'll post follow-up answers.
This is Mississippi...no one cares...as long as your windshield isn't cracked you pretty much pass...it's the good ole boy syndrome...
My husband is on his way home now so he can tell me then how he had his "special" wires and bypasses and such. Will let everyone know how it goes.
Hey. I did a swap with an efi 4runner and a carb pickup. I used The carb setup for simplicitys sake. All I did was swap out the distributor,gas tank, and intake. A lot of the stuff was pretty straight forward and it runs well.
I did this, 22R into a 1992 22RE truck. Further up in this thread is how I did it.
It's not hard, if you have wiring diagrams. The 22RE truck has all the connections where the injector harness is removed. It's only like 5 wires and everything works!
the easiest thing to do probally is to take the steering collum out, the whole dash then snake the old wiring harness out then put ur new one in wth the new computer and piece the dash all back together. This sounds like a lot of work but the dash goes togeter like a set of legos
sandyota
Feb 4, 2021 11:16 AM
