Engine Swaps Swapping an engine in your Toy, here is where to learn how
got a tranny question
Old Jul 28, 2009 | 02:48 PM
becks86yota's Avatar
Does anyone know if an auto trans out of a full size bronco will fit in an 86 4runner and if anyone has done this swap what kind of problems will there be.
Old Jul 28, 2009 | 08:38 PM
Adam F's Avatar
No, no, and NO
You must not know much about trucks.
Old Jul 30, 2009 | 03:59 PM
what you must not be much of a fabricator bc anything is possible.
Old Jul 30, 2009 | 04:29 PM
oh bc im doing a small block ford swap and i need a trans to back it up. If anyone has an idea what the best trans is going to be to back it up bc i dont think the w56 is going to hold up to around 350hp.
Old Jul 30, 2009 | 06:45 PM
Adam F's Avatar
Uh yea, I know how to fab, I put a 350 in my junk
Anyways, you diddnt mention you had a small block for in there. You just said "86 4Runner" so I assumed you still had the 4cy. You asked if it will FIT. I assumed by fit you meant "bolt in"
You suck at the internet.
What do you want to know? Build a crossmember, and go. Just do it.
Tranny? Are you looking to go Ford, or keep it Toyota? R150/1 will hold up.
Auto? Manual?
C4/6? AOD? T5? T18? NP435?
Old Jul 30, 2009 | 07:55 PM
RobD's Avatar
Duplicate.
RobD's Avatar
Old Jul 31, 2009 | 05:04 PM
well just bc you put a 350 in your Junk doesnt prove anything but if it makes you fell like you know somthing then more power to ya. My question is if anyone on here has used a c6 in a 4runner and if so what kind of clearance issues are their bc i havent purchased the trans yet so i cant mock it up im just trying to get an idea.
Old Jul 31, 2009 | 07:30 PM
Adam F's Avatar
FINALLY! A specific question that I can answer!
I think it will fit just fine. The C6 isnt that big. I've pulled dozens of them out of equipment at work. If you want, I can get some rough measurements of one and you can measure your truck and see if it will fit. I think the hardest part will be fitting the transfer case.
Old Aug 2, 2009 | 03:49 PM
yeah that would be much apreciated and help me get a start on the project.
Dieselmann
Feb 19, 2019 02:57 AM
Tonetrk
Aug 6, 2015 10:06 AM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
Iceman4193
Jul 15, 2015 04:48 PM
madxman21
Jul 9, 2015 10:26 AM
