SAS help
SAS help
Hey I am looking to finally straight axle swap my 93 extra cab pick up. I wheel a lot and ifs never really held me up THAT bad lol but I wanna run air lockers and bigger Tires. I have the allpro rear lift on my truck and I am really empressed with allpro. Do you guys recommend allpro SAS kit? Or trail gear? Also anyone selling a front axle? Can't seem to find one.
I would suggest putting your location about buying a front axle myself. Might be one in your area. I would imagine shipping being expensive on one. I dont have any suggestions on which brand to use.
Your budget might be cutting it close. The allpro kits is gonna lift the front quite a bit so rear will need to match. That means bigger tires which means lower dif gears. If you wheel your gonna want lockers. Bigger tires and lockers means you'll want upgrades birfields at a minimum depending on tire size. Plus long slip DS.
Got a lot to plan out. Check out marlin's forum loads of guy there from cali so might be able to find stuff local.
Take your time and build it right.
JookUpVandetti
Sep 30, 2015 08:58 AM
Toys4parts
Sep 26, 2015 01:56 PM
