Post up your SAS pics and specs
Old Jun 7, 2012 | 08:43 AM
  #141
racerflea's Avatar
Looks like u went through some deep water!!!
Old Jun 7, 2012 | 09:28 AM
  #142
TurboTruggy's Avatar
Nothing over 3 feet, I try avoid water and mud
Old Jun 9, 2012 | 04:36 PM
  #143
superswamper003's Avatar
[IMG][/IMG] heres my truck that i recently traded
5" SAS
85 axle, welded 4.10s with longfields
Old Jun 9, 2012 | 04:40 PM
  #144
Excuse the WD40 mess on the windows...
Old Jun 9, 2012 | 06:44 PM
  #145
vang_22re's Avatar
Looks good swamper!! What size are those tires. Need bigger ones
Old Jun 9, 2012 | 07:13 PM
  #146
streetlancer's Avatar
Originally Posted by superswamper003
5" SAS
5"? It looks too low to be 5". Trail-Gear 5"? Tire Size?
Old Jun 9, 2012 | 08:10 PM
  #147
I didnt have the money for 35s or 37s and gears so i just got 33s, their falcen rocky mtn ats
Old Jun 9, 2012 | 08:12 PM
  #148
Their 33/11.5/16s, and its a 5" eliminator kit. It really wasnt a small truck haha, was bigger than my friends truck with a 3" sas and 35s
Old Jun 11, 2012 | 09:54 AM
  #149
my buddy is running the TG 3 hd springs on a 92' runner with sbc 1 tons and 42's. Lots of trimming was done but it sits really low. When he was building it he bought 5inch TG's and it sat way to damn high, so he swapped them for 3's but we all know tg's bend and go flat under any weight so he went to HD's which still haven't settled giving it a cali lean.
before the roll over and new leafs
after, the HD's still haven't settled down
Old Jun 19, 2012 | 10:56 AM
  #150
Thump's Avatar
Here's my '86 long bed! I'm sporting a D44 with Ford outers with Ford disc brakes, read Ford 9 with Chevy parts and Ford rotors for rear disc brakes, and rear Chevy 63's. It's all Chromolly axles with Detroits and 5.29 gears on 37's with 17in Dodge Ram wheels. So I'm a Yota with Ford, Chevy, and Dodge stuff lol.
First pic on 39's
Old Jun 20, 2012 | 07:45 PM
  #151
alove0750's Avatar
It's not much, but here is my pile of hell
2001 Tacoma Prerunner
Drivetrain
3.4 V6 with 140,000
1997 4Runner automatic transmission
Inchworm adapter with 79 gear driven case with 4.7
Front Axle
79 Toyota Pickup
4.56 gears and bearings
Spartan locker
79 FJ40 vented rotors
95 4Runner Calipers
Trail-Gear 2in wheel spacers
Trail-Gear chromolly hubs
Trail-Gear HD drive shaft
Trail-Gear diff guard and bracing
Rear Axle
Factory E-locker
Front Suspension
Custom 3 link --> done by M.O.B.S. Fab
Wheel base stretched 1.5 inches
2 in, .25 wall DOM on the links
Trail-Gear 6 Shooter knuckles and high steer
Fox 12in Coilovers
Eibach 10in, 250lb top coil
Eibach 14in, 350lb bottom coil
Rear Suspension
Stock springs with three leafs out of another Toyota leaf pack, cut to length
2 inch Toytec Shackles with new bushings
12in Fox 2.0
Tires
33x12.50r15 Goodyear MTR Kevlars
15x8 Eagle Alloy's
Armor
All work also done by M.O.B.S. Fab
Bumpers, front and rear
Sliders
Full under belly skid
Lighting/Electronics
Custom retrofit HID swap (done by me) with 5K bulbs
Swap the Hella 75FF in the front bumper to 5K HID's
Dash and panel swap to blue LED's
White LED's in the map and dome lights
LED's in the front corners
LED tail, reverse and turn signals
7in LCD in dash screen
8,000lb Smittybilt winch
12 Volt Guy winch control
Old Jun 21, 2012 | 09:29 AM
  #152
Very nice
Old Jun 21, 2012 | 10:28 AM
  #153
vang_22re's Avatar
That tacoma looks good!! And its sitting on 33's. One word..perfect!
Old Jun 25, 2012 | 08:14 AM
  #154
alove0750's Avatar
Thanks guys! I wouldn't say it's "perfect" by any means but it suits my needs pretty good. It's daily driven between 200 and 350 miles a week and does pretty good off road too.
Old Jun 25, 2012 | 11:48 AM
  #155
Hey did you have to modify your rear driveline for the tcase swap? Also how much did it cost for the tcase swap?
Old Jun 25, 2012 | 01:21 PM
  #156
alove0750's Avatar
I had around $1200 in the case/gears/installation.
I had to put a different yoke/flange on the driveshaft because of the flange that came on my case (it was a bastard case from what I heard) but my stock joints were shot and loose at the end caps.
Old Aug 26, 2012 | 10:53 AM
  #157
85Xtra-Cab's Avatar
Originally Posted by ScottyC
Addicted Offroad custom front 3-link. 14" Fox 2.0 reservoir coilovers. Rear Addicted Offroad Dual triangulated 4-link. 22.5" frame height on 37s. 9.5" Diamond axles, dual cases, etc. Daily Driver.
I really like that setup.. How does it handle on the road as a daily driver? As in making corners and driving somewhat fast. Awesome looking rig.
Old Aug 26, 2012 | 12:25 PM
  #158
85TurboRunner's Avatar
Did a bit more than a SAS. Started out as a 2WD truck.
Used TG 3" front springs and some old Pro-Comp 4" springs in the rear. Also has the 6" shackles from Wab-Fab.
I'm running 35" Goodyear MTR's old style.
No action shots yet, maybe never. This thing will be a pavement princess for the most part.
Old Aug 26, 2012 | 12:47 PM
  #159
racerflea's Avatar
Looks good but put a front drive line in a pavement princess?? A 4x4 ifs front would have done the same
Old Aug 26, 2012 | 12:58 PM
  #160
I don't follow? I should have converted it to IFS 4x4? Yeah I needed a front driveline to make it work.
Um my definition of a pavement princess involves trips to the beach and camping that sometimes requires 4WD. But most of the time this truck will be on pavement.
