full width?
Old Aug 28, 2008 | 06:15 PM
martinpl's Avatar
full width?
ok yall i have been looking and looking i have found a lot of people putting dana 60s on their toyota. i have an 89 pickup sas'd. i am wanting to put dana 60s front and back. i am just not sure that if full width is the way to go. i dont want to have to cut the axles down. i live in GA and there aint a whole lot of rocks where im at but i do bog and trail ride and climb whatever there is to climb. question is how much bigger are 60s than '84 front axle, and will the d60s still allow trail riding?
Old Aug 29, 2008 | 01:27 PM
Mythica's Avatar
Not sure the size dif between those two axles.
But i love my full width set up, although i am running a D44 and a 9". the 60's from what i understand are a little bit wider than what i am running.
My front axle is know around 7" (IIRC) wider than my truck was stock.
It is tight when going through some tree filled trails, but i usally manage to get around most stuff so far.
Not sure about GA, but if mud flaps are needed, it would make it a little more interesting.
Good luck man!
Old Aug 31, 2008 | 06:43 AM
martinpl's Avatar
ok cool then i will probably go ahead with full width then. how do you like your 44s what did you get them off of. and what kind of transfer case do you have?
Old Sep 1, 2008 | 02:20 PM
bigarms23's Avatar
on my 4runner full width swap i got my d44 from a 85 grandwagoneer. and i would stick with toyota transfercase.
Old Sep 1, 2008 | 02:33 PM
martinpl's Avatar
oh really. why would you stay with the toy tcase. how much was the adapter for it. i am guessing probably somewhere around the same price for a d300
Old Sep 2, 2008 | 08:46 PM
bigarms23's Avatar
i went with dual toyta tcases and made my own driveshaft flange to use my front toyota driveshaft. I also kept the toy duals because i already had them insatlled
Old Sep 3, 2008 | 08:19 AM
Mythica's Avatar
I love the hp44 up front, kinda wish i would have fronted for a 60, but maybe down the road. I built my 44 to the hilt, the only issue i have had is blowing up the hubs. My chromo shafts and super joints havent been an issue at all. I love the 9" outback, it will stay with the truck forever now, its also fully built with the exception of disk brakes, they will come later.
I got my 44 out of a 79 bronco, I dont think you will want that though, as it had cast in wedges for the radius arms. I used a radius arm set up so i didnt mind. Although, i would rather have gotten one with welded on wedges,they are stronger. I think an 78 bronco/f-150 is what you are looking for.
I am running my stock case along with an Inchworm 4.7 crawler. They make a flang that adapts a d44 to a yota Drive line, but chances are you will need a new drive shaft. I just had mine built with yota on one end and d44/9" on the others.
Good luck man!!
Old Jan 8, 2009 | 07:36 PM
MIDGET's Avatar
I have a 44 front and 60 rear and with h1 wheels i shouldn't be more that three or four inches wider that stock.
Old Jan 8, 2009 | 07:52 PM
4banginRunner's Avatar
Try searching around Pirate, alot more people on that board with full width Toys
83yotastockR
11
Nov 10, 2015 06:54 AM
smilen724
13
Nov 8, 2015 04:11 PM
Dale Johnston
11
Oct 31, 2015 10:22 PM
Obmi
Oct 4, 2015 11:30 AM
tylermx71
Sep 29, 2015 08:49 PM
