sas questions
Old Jan 11, 2009 | 01:03 PM
lightemup's Avatar
sas questions
im planning on doing a solid axel swap on my 88 toyota pickup. im gonna use an axle from a 85 pickup. im also thinking about using the kit from front range offroad. www.frontrangeoffroadfab.com it dosnt come with springs or steering. heres were my questions come in can i use the stock steering from the 85 and could i buy a skyjacker lift kit for the springs.
Old Jan 11, 2009 | 01:08 PM
neoworm0's Avatar
I'm pretty sure the stock steering isn't going to work. The 85 used a push/pull setup IIRC.
You can use whatever springs you like you just need to make sure they are the right length and height for your application. Why do you want a skyjacker lift kit specifically? I would imagine just buying the springs from Marin or Trail gear would be cheaper. Maybe not?
Old Jan 11, 2009 | 02:00 PM
scuba's Avatar
x2, Why not just piece together the rest of the pieces from marlin..?
Old Jan 11, 2009 | 06:08 PM
jacruz2's Avatar
If your trying to save money you could always do a low steer setup like this
this is how it looks all mounted up
Old Jan 11, 2009 | 09:02 PM
lightemup's Avatar
how much does low steer setup cost. well skyjacker lift kit i can get leaf springs front and rear i need new ones for the rear anyway i have a cracked leaf in both and they lost the arch and it also comes with shocks. and i was just wanting to use the tie rods from an 85 i would think they would be long enough
Old Jan 11, 2009 | 09:36 PM
Tofer's Avatar
Sponsor
why not get a trail-gear SAS kit? it has EVERYTHING you need... big break up grade, hi-steer, springs, brake lines, shocks, etc etc etc.
i am a trail-gear dealer... PM me for pricing.
Old Jan 11, 2009 | 10:03 PM
jacruz2's Avatar
Not sure if anybody sells a kit I've only seen people make the steering arm by welding a piece of another steering arm on to the stock steering arm. I'll try and find a pic to help explain
Old Jan 12, 2009 | 12:14 AM
jacruz2's Avatar
I found better Pics
Mounted
Your only saving money by not buying high steer arms but you still have to buy all the other steering junk.
Here is a link to the thread on PBB about low steering
http://pirate4x4.com/forum/showthrea...t=low+steering
Good luck on your build and I hope I this helps you.
Old Jan 12, 2009 | 06:24 AM
toyminator2000's Avatar
Nobody makes those low steer crossover steering kits anymore because hi-steer is better and doesn't cost any more. The SAS kit from Front range is designed to use a slightly longer than stock spring and it moves the axle forward about 1". Skyjacker springs are made to be stock replacement lift springs for 79-85 trucks. Most likely your shackle angle will be wrong. The stock j-arm steering will only work for lifts springs 3" or less. Even then they are sloppy compared to crossover.
Old Jan 12, 2009 | 05:55 PM
lightemup's Avatar
ok heres another ? can i lengthen my stock driveline or do i have to buy diffrent kind. and most builds i see people put new leafs springs in the rear is this a must or can it wait. i would like to do everything at once but i cant afford it
Old Jan 12, 2009 | 06:03 PM
sa51's Avatar
i def wouldnt recc the skyjacker springs, too stiff. i'd go with marlin,all pro, or trail gear.
edit:i've seen a driveshaft spacer at 4crawler.com but idk if it is worth buying, mabye other members with more experience can chime in?
Old Jan 12, 2009 | 06:40 PM
waskillywabbit's Avatar
When you do a SAS and lift an IFS Toyota 3"+ you will need the high cross over steering, you can reuse your IFS steering box but need to remount it with plating the frame, and you will need to lenghthen both the d-shafts, but the front especially as it will not even be long enough to connect anymore (need a longer slip spline).
Flying91
45
Apr 11, 2024 04:39 PM
Shagool22
Aug 14, 2015 12:24 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
