lockers
It depends on what type of driving your '85 sees. If its strictly a trail toy you might just weld the side gears to the ring gear. If it sees some pavement but not ice or snow a Detroit or Lockright might be right for you. If Its your daily driver and you have a snowy or icey winter you want either an ARB airlocker or the Toyota electric locker from a '96-2000 4Runner.
Read this article, Its about putting a Toyota E-locker into an '85 4Runner rear differential. Its the Locker i'm running in my '87 truck and its awesome. The pieces to install it came from a junkyard and Radio Shack (for the relays to control it) Total cost, $322
Call me the junkyard king. You can do a lot to make a Toyota better for trail running with cheap ass junkyard parts.
I dont think any came with 4:88, just 4:10, 4:30, and 4:56. Also if your Toy is a 2wd pickup, then your springs are "sprung under" the axle, and the 4wd is "sprung over" the axle. That would be an issue
GEAR
Usually, but not always:
4 cyl, manual trans - 4.10
4 cyl, auto trans - 4.30
4 cyl, auto trans, FACTORY 31" tire package - 4.88
4/6 cyl, manual trans, FACTORY 31' tire package - 4.56 2wd pickup, springs are "sprung under" the axle, and the 4wd is "sprung over" the axle. This is a easy fix i have a MIG. Want year rear do i want .
Re: REAR
Originally posted by AZTOY
96 -02 Taco of 4 runner, I will see if i can find a rear and let you know if i can make it works. THANK YOU AZTOY
TheBFA
Feb 15, 2020 06:55 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
Toys4parts
Sep 26, 2015 01:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
Sep 24, 2015 03:30 PM
zz_denis
Sep 6, 2015 03:43 PM
