Off Road Trip Planning, Expeditions, Trips, & Events Discussion pertaining to scheduling trail runs and outings
lockers
Old Aug 22, 2002 | 12:36 PM
wrongway's Avatar
lockers
Was wondering where best place to buy a locker for my 85 rear axle?
Also how much they run?
Old Aug 22, 2002 | 04:44 PM
jx94148's Avatar
It depends on what type of driving your '85 sees. If its strictly a trail toy you might just weld the side gears to the ring gear. If it sees some pavement but not ice or snow a Detroit or Lockright might be right for you. If Its your daily driver and you have a snowy or icey winter you want either an ARB airlocker or the Toyota electric locker from a '96-2000 4Runner.
Read this article, Its about putting a Toyota E-locker into an '85 4Runner rear differential. Its the Locker i'm running in my '87 truck and its awesome. The pieces to install it came from a junkyard and Radio Shack (for the relays to control it) Total cost, $322 Call me the junkyard king. You can do a lot to make a Toyota better for trail running with cheap ass junkyard parts.
Old Sep 4, 2002 | 08:21 PM
AZTOY's Avatar
Lightbulb LOCKER
CAN WE PUT THE WHOLE REAR END IN A OLDER TOY . THEY GOT BETTER GEARS AND A LOCKER.
Old Sep 5, 2002 | 07:40 AM
data's Avatar
Senior Member
Re: LOCKER
Found this on the ODW forums...lol!
Old Sep 5, 2002 | 08:44 AM
crash's Avatar
The trick is to put a rear housing from an IFS rig, 3" wider..
Then to go full bore get a V6 carier
Old Sep 5, 2002 | 09:36 AM
AZTOY's Avatar
rear
Ok sorry about the caps : bang: . So the newer rear is 3 in wider. That is fine by me. Are the spring perchs the same or do i need to cut the them off and weld on new ones?thanks
Old Sep 5, 2002 | 09:43 AM
crash's Avatar
Its a bolt on deal, just might have to rework the shocks...
Old Sep 5, 2002 | 10:09 AM
AZTOY's Avatar
rear
The shocks are easy fix want . I want a rear with the 4.88 gear and e-locker do you know want years came with both?i want to run 31 on my 2 wheel drive toy
Old Sep 5, 2002 | 02:20 PM
Adam F's Avatar
I dont think any came with 4:88, just 4:10, 4:30, and 4:56. Also if your Toy is a 2wd pickup, then your springs are "sprung under" the axle, and the 4wd is "sprung over" the axle. That would be an issue
Old Sep 5, 2002 | 02:42 PM
AZTOY's Avatar
GEAR
Usually, but not always:
4 cyl, manual trans - 4.10
4 cyl, auto trans - 4.30
4 cyl, auto trans, FACTORY 31" tire package - 4.88
4/6 cyl, manual trans, FACTORY 31' tire package - 4.56 2wd pickup, springs are "sprung under" the axle, and the 4wd is "sprung over" the axle. This is a easy fix i have a MIG. Want year rear do i want .
Old Sep 5, 2002 | 02:53 PM
Adam F's Avatar
BUT----the only years that came with the e-lcokers are 96-02 4Runners and Tacomas, and those gear charts do not apply to these years.
Old Sep 5, 2002 | 05:11 PM
AZTOY's Avatar
REAR
96 -02 Taco of 4 runner, I will see if i can find a rear and let you know if i can make it works. THANK YOU AZTOY
Old Sep 6, 2002 | 05:06 PM
jx94148's Avatar
Re: REAR
Remember that 4Runners with E-lockers have rear coil springs, panhard rods and control arms. I think the Leaf springs on Tacos are farther apart than on '84 -'95 trucks and pre '90 4Runners. A complete rear axle swap is possible but not a straight bolt on swap. You will have to make spring perches.
TheBFA
Feb 15, 2020 06:55 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
zz_denis
Sep 6, 2015 03:43 PM
