General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
I hit the brakes...The parking lighths come on
Old Feb 21, 2010 | 06:22 PM
frombozeman's Avatar
87 4runner doing some funky things, but seems to settling on parking light and dim dash lights coming on when I hit the brakes. Bad ground?
Old Feb 21, 2010 | 06:29 PM
4Crawler's Avatar
Might want to check those rear bulbs, could be one has shorted internally causing the parking lights to come on with the brakes (that is a dual filament bulb). Try removing one bulb at a time and test if the problem goes away.
Old Feb 21, 2010 | 10:30 PM
thanks. That's a great idea. Didn't work for me. I'll keep scratching my head
Old Feb 22, 2010 | 11:50 AM
4Crawler's Avatar
Any trailer wiring box installed on the truck? If so, try disconnecting that and see what happens.
Old Mar 7, 2010 | 01:43 AM
wyoming9's Avatar
Red face
If you do have a bad ground back in your taillights due to a corroded socket it will ground back into the parking lights .
I say clean the bulbs and sockets with contact cleaner and see what happens
Old Mar 7, 2010 | 04:34 AM
rxs1907's Avatar
it is the rear bulbs dual filliment
I too had the same problem, the rear bake bulb top wire shorted out and rested on the lower wire, that is the exact symptom. I was only looking for a blown blub you really have to take it out and hold it up to the light and look very carefully.
Old Apr 3, 2010 | 09:02 PM
Ron Helmuth's Avatar
update please? This is fairly common so let's hear what you found out...or still no solution?
Old Apr 13, 2010 | 05:27 PM
Rusted Rooster's Avatar
I am having same symptoms ......push brake and dim dash lights and signals any fix?
Old Apr 13, 2010 | 09:07 PM
SoCal4Running's Avatar
Mine was a trailer wiring issue. The 4runner had a 4 wire plug where the brake lights were spliced with the parking lights and stepping on the brakes would feed back into the parking circuit.
Needed a 5 wire plug to fix.
theBAYsic
Sep 16, 2015 05:21 AM
Boomer8404
Sep 10, 2015 09:01 AM
anndel
Sep 10, 2015 08:50 AM
ErikZ1220
Sep 10, 2015 04:53 AM
djpg2000
Sep 7, 2015 10:36 AM
