General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
86 Toyota pickup poor headlight lighting
Old Dec 25, 2018 | 05:24 AM
Bpitts23's Avatar
Just installed h4 headlights with hids. Bought h4 adapter with relays everything is wired. Checked prongs and have 14 14 and 0 on prongs per multi meter. Still piss poor low beam lighting. A flash light shines brighter. Any suggestions
Old Dec 26, 2018 | 05:48 AM
se7enine's Avatar
If they are cheap FleaBay hids throw them away. If they are installed in a stock halogen reflector then take them out.
Old Dec 26, 2018 | 06:37 AM
Bpitts23's Avatar
Yes
They were from Ebay. But just ordered the led headlights. Is that better.
Old Dec 26, 2018 | 08:38 AM
se7enine's Avatar
Only if they are Truck-Lite LED's.
Old Dec 26, 2018 | 04:46 PM
Bpitts23's Avatar
Yes they are from truck lite. But still why is my headlights dim with hids. Is the plug configuring wrong . Also the h4 conversion plug shows 14 volts on 1 prong and 0 on the other 2. Is that correct .
Old Dec 26, 2018 | 05:09 PM
Discombobulated's Avatar
Could be many factors, the housings are set up for standard bulbs, once you put an HID bulb in a standard housing the Correct reflecting is out the door HID bulbs work or they don’t unless they are bad. Voltage will cause flickering but not brightness issues.
Any pics of the housings or the set up?
Old Dec 26, 2018 | 05:53 PM
se7enine's Avatar
What HID's did you buy and did you test them directly to 12V before installation? I always test the ballasts, igniter and bulbs before use.
Old Dec 26, 2018 | 10:57 PM
RAD4Runner's Avatar
Bulb upgrades are useless if you keep stock wiring. In fact higher power bulbs could damage stock wiring and your headlight dimmer combo switch.
H4 conversion harness should come before bulb upgrade. Pls search more.
Old Dec 27, 2018 | 05:39 AM
se7enine's Avatar
I think he said he got an H4 adapter with relays.
Old Dec 27, 2018 | 01:04 PM
RAD4Runner's Avatar
Oh, I see.
Originally Posted by Bpitts23
Just installed h4 headlights with hids. Checked prongs and have 14 14 and 0 on prongs per multi meter.
Did you try the stock halogens to test if your H4 conversion harness is good?
Which prongs are which, how are you probing and in what position? Please see signature.
When you get your conversion harness working, I recommend Truck-lites LED, instead. Plug and play, I switched mine in the parking lot.
PLUS, they are not polarity-specific. Work with switched-ground (stock) or switched positive (most H4 conversion harnesses).
Old Dec 27, 2018 | 10:55 PM
Bpitts23's Avatar
This is how the prong is set up now for h4 harness .
Old Dec 28, 2018 | 05:51 AM
se7enine's Avatar
Cheap HIDs is one reason for low output and on top of that 8000k bulbs make it even worse. It also looks like a shielded bulb and a poorly designed reflector housing that weren't designed to work together so less usable light actually reflects out.
Old Dec 28, 2018 | 10:16 AM
RAD4Runner's Avatar
Tnx for the info, but... simple things are best.
I repeat,
Old Jan 6, 2019 | 06:44 PM
thefishguy77's Avatar
Rad. What harness do you recommend for the truck-lite leds.
Mine is a stock 85 4runner SR5
Old Jan 6, 2019 | 07:49 PM
RAD4Runner's Avatar
Happy New Year, Guys!
I simply rewired mine to add a relay in place of the dimmer combo switches, HERE. Electrically simple, retains my switched-ground system and uses only one relay but to some it may feel like performing surgery - LOL!
For most people, a good H4 (refers the connector) conversion harness should work. (Sorry I haven't personally tried the commercial ones.) Most H4 conversion harnesses convert to switched-positive. Some LED lights work only with switched-ground or with switched-positive. My Truck-lites work on switched-ground that I have, and TL's tech support confirms that they will also work on switched-positive.
Old Jan 6, 2019 | 07:57 PM
RAD4Runner's Avatar
Yes they are from truck lite. Is the plug configuring wrong . Also the h4 conversion plug shows 14 volts on 1 prong and 0 on the other 2. Is that correct .
That's correct pin configuration^^^
You need to do tests if you are to figure this out.
Start with STOCK wiring and do tests I describe or prescribe (LOL) here.
Then let us know what you find out.
bend
Oct 14, 2012 03:50 PM
dropzone
Jan 13, 2012 05:35 AM
2003mikem
9
Nov 4, 2011 06:19 AM
Mossback74
11
Nov 4, 2010 03:29 PM
Djlarroc
Oct 12, 2007 04:00 AM
