What is broken on YOUR Toyota
Old Jan 21, 2015 | 11:23 AM
  #1201
muddmadness's Avatar
No water or fluids in the oil
Old Jan 21, 2015 | 01:01 PM
  #1202
millball's Avatar
Does'nt always put coolant into the oil. Sometimes just puts combustion gasses into coolant.
Old Jan 21, 2015 | 01:23 PM
  #1203
So you don't think it could be the thermostat stuck closed, I hear also that there is a design flaw with the 85-95 22re that involves the thermostat requiring a hole being drilled through it. I haven't checked for circulation yet either.
Old Jan 21, 2015 | 01:25 PM
  #1204
millball's Avatar
Guess stuck thermo is possible.
Does it start bubbling right away, or wait until warm-up?
Old Jan 21, 2015 | 01:26 PM
  #1205
Does it after it warms up
Old Jan 21, 2015 | 01:28 PM
  #1206
millball's Avatar
Easy enought to remove the thermostat and examine it, or just change it out.
You'll know soon if that's the trouble.
Old Jan 21, 2015 | 01:31 PM
  #1207
I agree I am also going to let it run with the hood up and see what happens just to be sure. I don't have a drill with me right now so I think I will check into a two stage thermostat.
Old Jan 21, 2015 | 01:34 PM
  #1208
How do I check for combustion gases in the coolant, never mind found it. Not that hard to do.
Old Jan 22, 2015 | 12:53 PM
  #1209
Turned out to be a hose clamp issue on a brand new top end hose. Crazy truck.. Just as much love today as the first time I laid eyes on it.
Old Mar 5, 2015 | 01:28 PM
  #1210
mdel's Avatar
I broke my 4WD
I could use some advice on this. I have a 1980 4WD pickup which died 10 years ago with 385K miles on it. Since I couldn't bare to part with it, I decided to give it new life by way of a Mercedes OM617 conversion. Because I am not a mechanic, it took me 10 years and lots of help to get it done. But it's done, and it works, and I LOVE it! the most recent problem: I was driving on snow and ice covered pavement, going about 30-40mph. Several cars went off the road around me, so I decided to engage the 4WD for the first time since the rebuild. I locked the hubs, put it in 4HI, and drove off. It felt very good for about 5 minutes, and then there was a horrible sound and the front wheels locked up. I barely managed to pull off the road, unlocked the hubs, put it back in 2HI. It drives fine in 2. I put a solid axle from a low mileage 1985 4-Runner and 17" wheels on the truck when we did the engine swap. I'm starting to wonder about the increased wheel size and what that may have done to my transfer case. I saw smoke around the front differential at the time of the jam-up, so I'm wondering about that, too. And also about that birfield joint. Any advice will be hugely appreciated! Thank you!!
Old Mar 8, 2015 | 02:55 PM
  #1211
thefishguy77's Avatar
What oil are you running in your new front diff. Congrats on the motor swap BTW
Old Mar 8, 2015 | 06:51 PM
  #1212
mdel's Avatar
Hi thefishguy! I went with synthetic- AMSOIL. can that create problems? and thank you for your response.
Old Mar 8, 2015 | 08:09 PM
  #1213
I don't know much about that oil. How does the oil smell? Burnt? But if it meets the FSM requirements then your probably good to go. I was just thinking that was an easy thing to check. Have you crawled under it and looked for bright metal as in fresh breakage? How do your wheel bearings look? Just throwing ideas out there.
Old Mar 9, 2015 | 08:39 AM
  #1214
mdel's Avatar
hm... ok I'll check the oil. I'm pretty sure it's to Toyota spec. No breakage is obvious from the outside. Maybe I'll just start taking apart the front differential and see what happens.
Old Mar 9, 2015 | 12:27 PM
  #1215
Smell your oil before you take anything apart. If it smells burnt you have narrowed your problem.
Old Mar 9, 2015 | 06:34 PM
  #1216
808_4runner's Avatar
G'day
Does anyone know where I can exactly find my 'DOOR CONTROL' relay module?
85980-89101
this is the part number. i am going to try to repair the circuit.
Old Mar 9, 2015 | 06:37 PM
  #1217
93Xtra-Cab's Avatar
Sometimes when I turn my lights on, my drivers side rear running light doesn't come on, so I have to get out and hit the lens for it to light up, similar to the way Fonzie hits the jukebox to play music on Happy Days.
Old Mar 9, 2015 | 07:11 PM
  #1218
arkansasfamily's Avatar
Bought the truck 1 month ago. Changed most of the front end, Front and rear brakes. Transmission service leading to probably rebuild or swap. Also need to change timing belt, water pump, idler pulleys, cam seals, crankshaft seal, oil pumpoil pan screen, remove egr and pair, New exhaust. Check valve clearence, 4 inch lift, bigger tires, new front bumper with winch, repair or replace torsion bars, rear bumper. fix high beam switch, Check out ac, repair clear seal on paint. Should be ready then.
Old Mar 10, 2015 | 04:13 PM
  #1219
cjskeen14's Avatar
power steering line leak!!! the metal line that goes from the gear to the pump. about 14 inch end to end. impossible to find at any auto wrecker or Toyota dealership. Anybody know a way I fix this? or even where the hell I can buy a new one? maybe steel braded line? Off of a 1982 Toyota pickup DLX
somebody tried to wire feed weld this lol
Old Mar 10, 2015 | 05:01 PM
  #1220
Try 22re performance. They have a lot of out of production parts for these motors.
