Uknown wheel size question
Old May 17, 2007 | 04:47 PM
2WDoffroadx's Avatar
Im running 30x9.50 AT BFG on aftermarket wheels.
Im not sure what size the wheel is. Nor do I know the backspacing..Btw, what is back spacing?
Do you think I would be able to run 31x10.50? The Fabtech lift states that I should have 30x9.5 tires. Why is this? Do I need to follow it? Or can i go bigger?
Old May 17, 2007 | 04:55 PM
Elton's Avatar
hmm should say 30x9.5x15 and by looking at your pics in you sig looks like 31x10.5s should fit with no problems
Old May 17, 2007 | 05:04 PM
is the 15 the diameter of the wheel? Im not sure where to measure it but I started exactly where the wheel meets the tire, all the way to the other side. It was about 16.25".
What does this mean?
Also, what is the "backspace" of a wheel?
Thanks
Old May 17, 2007 | 05:05 PM
Also, what is a good Offroad wheel brand with good prices? I am looking for the black alloy wheels.
Any ideas?
Old May 17, 2007 | 05:07 PM
Elton's Avatar
15 is the rim size
Old May 17, 2007 | 05:09 PM
Don't bigger tires decrease the vehicle's pickup and all around speed?
Old May 17, 2007 | 05:19 PM
881stGenRunner's Avatar
yes, to easily find out what rim size you have look at the tire where it says 30x9.5R15.
Old May 17, 2007 | 05:51 PM
Bill's Avatar
Thanks
The rim is a 15" because thats where the bead of the tire sits. There needs to be a lip on the rim so the bead can't fall off:
0 0
00000
15"
00000
0 0
The same goes for the width: an 8" rim measures about 10" wide, but only 8" between the "lips" of the rim that the bead seats against.
Backspacing is how far from the back of the rim the hub mounts, and so determines how far out your wheel stick. It's measured by placing the rim on the ground(with the inside facing up), lay a straight edge on the rim, and measure down to the mounting surface.
less backspacing = wider (but more rubbing)
more backspacing = narrower (but less rubbing, usually)
glowz825
Jan 25, 2022 09:28 AM
rushw
Jul 18, 2015 01:46 PM
dropzone
Jul 16, 2015 02:00 PM
87turboPA
Jul 12, 2015 07:49 AM
Yotoder865
Jul 9, 2015 07:51 PM
