break in
Old Oct 2, 2006 | 08:57 PM
steveo2992's Avatar
break in
I have a 1991 4runner i just put new heads, gaskets, fuel injectors and all. What would be the proper way to break it in when i start it in a couple of days?
Thanks
Old Oct 3, 2006 | 11:08 PM
L33T35T 4Runner's Avatar
In the gas world they say keep it under 3k for the first 500 miles, no long constant speeds.
In the world of diesel engines that i build, we warm them up on a dyno then run the hell out of them until the rings seat
Old Oct 4, 2006 | 01:18 AM
AH64ID's Avatar
Did you replace the cam too?
If not you really dont have to have a break in procedre. I would change the oil filter after the first 10 minutes, then the oil at 100 and 500 miles, then back to normal..
Interesting comment L33 on the diesel.. the 06 Cummins requires a much different brake in. No cruise for the first 500 miles (to avoid constant RPM), then for the first 500 miles of towing no going over 50..
Old Oct 4, 2006 | 05:42 AM
maxpower_hd's Avatar
You didn't mention even doing the lower end. If all you did are the heads then just run it.
Old Oct 4, 2006 | 06:03 AM
oly884's Avatar
Guest
Yup, a lower end rebuild requires some break in period ditto. Top end doesn't require much except for checking for leaks for the first couple thousand miles.
To be on the safe side, I'd read this if I were you:
http://www.taperformance.com/howto.htm
It might give you some pointers or things to watch out for. Good luck!
Old Oct 4, 2006 | 08:40 AM
AH64ID's Avatar
If you did replace the cam(s) you will need to do the cam break in, IIRC its 2000rpm min for the first few minutes at initial fire up...
Old Oct 4, 2006 | 03:19 PM
steveo2992's Avatar
Yes i did replace the cams. I got a set of complete heads. i also have one more question. How do you prime the cooling system? can you just put 50/50 mix in the top water enlet thing and then fill the radiator and over flow. THANKS
Old Oct 8, 2006 | 08:39 PM
steveo2992's Avatar
I broke in the engine and runs great thanks
Old Oct 8, 2006 | 10:31 PM
AH64ID's Avatar
good deal
RDubya
Feb 10, 2017 04:46 PM
Obmi
Oct 4, 2015 11:30 AM
voiddweller
Oct 2, 2015 07:47 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
JookUpVandetti
Sep 24, 2015 02:58 PM
