Sponsored by: CARiD
stripped rear differential oil fill plug!!!!!
Old Apr 14, 2009 | 09:47 AM
92yotafan's Avatar
i have a 1992 toyota truck 4x4. I recently had a new rear end installed but my mechanic was to cheap to put a new pinion seal in it. so now about once every 2months i ahve to fill the rear diif with new oil. it is about that time but when i went to do so the head of the fill nut stripped. How do I remove the stripped plug to put in a new one?
Old Apr 14, 2009 | 10:15 AM
4Crawler's Avatar
Put in a new pinion seal:
- http://www.4crawler.com/4x4/CheapTri...eal/index.html
And for the fill plug, weld a nut onto the head of the plug and then use that to remove it. Or you may be able to use a chisel on the edge of the head to break it loose. And only use a 6 point socket on that plug.
Old Apr 14, 2009 | 11:01 AM
OSU4Runner's Avatar
Take it back to the mechanic and make him put a pinion seal in.....as for the diff plug, you can do what 4Crawler said. If you don't have access to a welder, the chisel method works well, or you vice grips as a last resort.
Old Apr 14, 2009 | 11:07 AM
DeathCougar's Avatar
The hammer and chisel method works well in a pinch. If you have access to a welder, that method is the fastest.
Once you get it off, change it with an allen head plug and you wont have that problem anymore.
Old Apr 14, 2009 | 02:42 PM
Trustyrusty's Avatar
tg ftw!!!
Old Apr 15, 2009 | 06:57 PM
92yotafan's Avatar
thanks guys . ill get on asap. oh does anyone know where i can get a 6 inch lift for my 92 yota. all i can find is 4 inch.
Old Apr 17, 2009 | 08:15 PM
You don't wanna do that.
Old Apr 21, 2009 | 10:41 AM
whokrz's Avatar
A pipe wrench might work too. A 2-3 inch lift would be better for a 92 with ifs.
Old Apr 21, 2009 | 10:28 PM
hellfire's Avatar
4 inch + 2 inch body lift
Old Apr 22, 2009 | 07:12 PM
83yota6996's Avatar
Vice grips as tight as u can get them, works great!
Jun 1, 2021 01:51 PM
voiddweller
19
May 2, 2016 09:10 PM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
