Sponsored by: CARiD
Problem gettin my truck to stay runnin. Help desired.
Old Oct 15, 2007 | 08:42 AM
everlasting289's Avatar
So i understand there is only a computer screen connecting us and you cant see the truck for yourself, but i could use some help. Just hooked up the new motor and she turns on, cranks over and starts up nicely. But she only stays on for 5-10seconds and dies. Any advice?? Played with timing but no luck. Thanks.
Old Oct 15, 2007 | 09:22 AM
CyMoN's Avatar
please put on your profile the year,motor,auto or 5 speed it is harder to come up with a answer if we don't have the basics is it carbed or EFI?
Old Oct 15, 2007 | 09:45 AM
93 toyota pickup with 92 22re EFI. sorry jus made this profile cuz i got a little fed up with my truck this morning. She's been down for 4 months and ive spent over a grand in the past 3 days alone in parts. Im actually assuming its a fuel problem, bad injectors or something. But thanks for the pointer, ill do it right away.
Old Oct 15, 2007 | 05:58 PM
rowdy235's Avatar
Check Fuel system. Also check fuel pump and electrical.
Old Oct 15, 2007 | 06:06 PM
4Crawler's Avatar
Check the Air Flow Meter:
- http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
and for a quick check, try the fuel pump test jumper:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Old Oct 15, 2007 | 07:11 PM
CanadianToy's Avatar
Clean the surface between your ig coil and the fender. Changed fuel pump relay, fuel pump, fuel filter before I discovered it was a bad ground on the coil.
just a suggestion.
CT
Old Oct 15, 2007 | 07:13 PM
Shoua's Avatar
Or check fuel filter. Could be plugged.
Old Oct 16, 2007 | 08:29 AM
thanks alot fellas. This mornin we actually got it going. It was a real dumb oversight. In a rush to see if the engine would run we neglected to attach the air intake. I guess she was pullin in too much air or something. We hooked up the intake hose from the air box and she started and held jus fine. Thanks again. Hopefully I can return the suggestions for some of yall someday.
GreenLion
Jun 7, 2021 10:49 AM
duckhead
170
Nov 13, 2017 06:07 AM
voiddweller
19
May 2, 2016 09:10 PM
bigblue82
10
Jul 6, 2015 08:27 AM
bowhunter1640
18
Jul 5, 2015 03:30 PM
