Sponsored by: CARiD
The OFFICIAL IFS "What size tire will fit" thread
Old Apr 16, 2010 | 05:46 AM
  #321
tiger's Avatar
im sure they do hmmm look in to the metric eqivulant i dont know what size it would convert over to but im sure someone on here could tell ya like a 305/50/r15 or something
Old Apr 30, 2010 | 07:50 AM
  #322
dpeppers's Avatar
93 t100 2wd
Whats a nice tire to go on one of these? It has stock 215/75/15s, and they look way to small. I want something that looks beefier, but isnt too thick since I wont have a lift or anything on it. 235/75/15s? Would those look a significant amount different?
Old May 1, 2010 | 05:02 PM
  #323
Yotamanmatt's Avatar
Breaking Prevention
I just put a 5 inch lift on my 92 Ifs 22re pickup, and put 36"X13.00 R16 super swamper TSL's on it, there not rubbing height or width wise but im goin alot slower and i was wondering if thats to big of a tire for my stock gears and stock suspension? like am i guna bust a CV joint or a U joint or am i guna blow my axles or what? and if something is guna break with that biga tire what should i do to prevent it?
Thanks
Old May 6, 2010 | 01:02 PM
  #324
shawns88's Avatar
quick question, i know 33s will fit but how wide untill they rub? i got 1988 ifs no lift.
Old May 6, 2010 | 02:28 PM
  #325
BackGateYota92's Avatar
pretty sure a 33x10.50 with the right backspacing wont rub
Old May 16, 2010 | 12:05 AM
  #326
SkippyD's Avatar
Why does every one want to move up from a 31 to a 33. Does that 2in make a whole lot of difference?
Old May 17, 2010 | 12:47 PM
  #327
U-Turn09's Avatar
Don't need much
I have a 99 sr5 with Toyo AT 265/75 R16's and no lift. I have not had any rubs or scuffs at all. I have not disconnected my sway bars and tried it but I really like my set-up because I am not changing any factory angles, keeping my center of gravity as low as possible, and its cheap. I wheeled all weekend with a bunch of Rubicons and could go anywhere they went. The only weakness I have right now is my approach angle sucks going into vertical surfaces but a lift isn't going to help that. PS I would buy the Toyo AT's agian- they haven't worn well.
Originally Posted by Colonel Angus
I'm settling on 265/75s as opposed to the awesome 255/85s. I don't want to have to regear and trim pinch welds, fenders, bumpers, etc.
So, my question to you guys is.....
What do you think will look the best? The 1.5" or the 2.5"? If I did the 2.5" would I need to drop the differential? Also, if I got the 2.5" with 265/75s....will I wish that I had got the 255/85s?
Let me know what you think and post pics if you get 'em.
Thanks folks!!!!
p.s It's a '99 4x4 Limited.
Old May 17, 2010 | 12:54 PM
  #328
xxxtreme22r's Avatar
1" extra drivetrain clearance can make the diffrence if you get high centered or not or smack a differential into rocks etc. when off-roading every inch counts. Especially when airing down tires. In this case load rating of 33" vs 31" might come into play as well but I personally haven't research the difference in ratings between the two.
Old May 17, 2010 | 04:54 PM
  #329
SkippyD's Avatar
true. i just want some one to tell me not to get 33s, so i can stop wanting(more like obsessing) some hot 33x10.50x15s
Old May 18, 2010 | 06:18 AM
  #330
Lumpy's Avatar
Well no one is going to tell you to get smaller...
Old May 18, 2010 | 08:45 AM
  #331
clocklaw's Avatar
I went with 31's...the stock size...been very happy so far:
Old May 18, 2010 | 08:51 AM
  #332
Lumpy's Avatar
I could fit 33's stock and withe the LC coils I'm stuffing 35's once I get the BJ spacers she'll be sitting much nicer.
Clocklaw, she's a looking purdy!!! Doesn't look like your sagging much maybe just a wee bit, how's the ride?
Old May 18, 2010 | 08:54 AM
  #333
yotaman85's Avatar
Originally Posted by tiger
well from what ive learned guys putting 12.50 and even 11.50 on stock rims is really a no no it can make premature tire wear and some tire manufacters wont warrenty the tire 10.50 is as big as you should go on a 7 inch rim 11.50 calls for 7.5 to 9 and 12.50 calls foe a 8.5 to 10.50 it can be done and put on those rims but you should check into getting wider rims later on
I have ran 12.50's on stock rims for years.. I actually prefer this set up to a 10" wide wheel. tire wear is not exaggerated and the possibility of breaking a bead when aired down is reduced considerably.. plus I think 12.5" wide tires on a 10" wide rim looks funny..
Old May 18, 2010 | 01:08 PM
  #334
clocklaw's Avatar
Lumpy, the ride so far is much better than the 235's. I am wanting some rancho 5000 shocks for it...as for the sag, that picture shows some sag but there were 4 tires in it at the time so a little extra weight back there.
Old May 19, 2010 | 09:24 PM
  #335
vanderwiel's Avatar
Will I notice a huge difference in the snow between a 31x10.5 and a 32x11.5?
im thinking of moving up a bit but idk..
i also found a guy selling a set of almost new 31' bfg mud terrains for 500 obo.. was thinking of possibly just lowballing him.. though i dont really need a mud tire...
Old May 24, 2010 | 08:12 PM
  #336
4ever4running's Avatar
Okay guys I have read just about every post on this thread and I still can't find what I am looking for. Everyone seems to have later model 4runners and I know the suspension systems are different...I have a 2002 4runner SR5 with stock 15" rims and a stock lift. Right now I am running 31 X 10.5 R15's with no fitment issues whatsoever, but I want to go bigger. I am looking at getting a Revtek 3" suspension lift. Does anyone know the biggest tires I can run with and without the lift?
From what I have read it seems like 33X10.5 R15 might fit without a lift, is this true?
Would I be able to go up to 35X10.5 R15's with a lift or are 33's the biggest I can go?
Will 33X12.5's fit with the lift?
Thanks in advance for your help and I promise I read just about everything in this thread and still didn't find the answers I am looking for so I apologize if this is a repeat question.
Old May 25, 2010 | 07:28 AM
  #337
AxleIke's Avatar
Originally Posted by 4ever4running
Okay guys I have read just about every post on this thread and I still can't find what I am looking for. Everyone seems to have later model 4runners and I know the suspension systems are different...I have a 2002 4runner SR5 with stock 15" alloy rims and a stock lift. Right now I am running 31 X 10.5 R15's with no fitment issues whatsoever, but I want to go bigger. I am looking at getting a Revtek 3" suspension lift. Does anyone know the biggest tires I can run with and without the lift?
The 33's will be fine.
As for the 35's, they'll probably fit, though its tough to tell. Keep in mind that the only thing you will find in a 35x10.5 is a bias ply tire, something from Interco likely, so be prepared for the characteristics of that tire: flat spots in the cold, road noise, etc...
Old May 25, 2010 | 02:49 PM
  #338
Okay well I think the 35's are definitely out, I want to stick to something like the T/A KO's or the Wrangler DuraTrac.
Any ideas on the 33X10.5R15's fitting without a lift?
Any ideas on the 33X12.5R15's fitting with a lift?
*Keep in mind I would like to keep my stock 15" rims
Old Jun 12, 2010 | 01:21 AM
  #339
cjs4runner's Avatar
im new i have a 86 4runner first yota just got it and wondering what tires i should go with i have 33's 80% back 0% front lol wondering if i should get 2 new matching 33's or maybe go 35's also thinking about getting a 4 inch suspension lift.?? any help???
Old Jun 21, 2010 | 06:48 PM
  #340
kochjohnny's Avatar
Can i put a newer bed on a 87 pickup? im having a hard time findin a good 88 style bed.. and fiberglass is too much for a mud truck..
