Sponsored by: CARiD
Need help with sluggish running 22rte
Old Jan 8, 2011 | 08:18 AM
84sdyota's Avatar
I bought this 4runner 5spd 4x4 22rte from a guy who blew the head gasket and had the head work already done so all i needed to do was put it back together. I had to put a helicoil in the block because one of the head bolt holes was stripped. got the motor all back together wouldn't run pulled the timing cover off with the head still on adjusted the timing chain to the right spots put it all back together again. i got it running but it runs real sluggish and and shakes the whole car at idle. ive checked the timing 3 times its good ive yet to do a compression test but am going to today. any suggestions will help??
wheres the best/cheap places to get a full gasket set with turbo gaskets and piston rings?
Old Jan 10, 2011 | 11:39 AM
snowboarder86's Avatar
If its not your cam or ignition timing it sounds like you might have a missfire. Have you done a basic ignition tune up? plugs wires rotor and cap? Assuming the engine was put together properly I would stick with the basics....
Not that I have much experience with it but a Holley 350 sounds like a pretty big carb for a 22r... was it running with it before or do other people run this setup? Iam more curious then anything
Old Jan 10, 2011 | 03:04 PM
84sdyota's Avatar
that was on my old toyota the 350 carb it ran good. i have new plugs and wires doing cap and rotor next pretty sure the timing is all set right
Old Jan 11, 2011 | 10:08 AM
It will be interesting to see the results of your compression test. I ran one on mine last night and it turned out a couple cylinders were low, not too thrilled about it
Old Jan 11, 2011 | 11:49 AM
Trail_Time_4x4's Avatar
are the plug wires in the right order?
was the shaved at all when the head was redone?
is there a mechanical knock when idle is rough?
does the rpm clime smooth?
check for play in the tubo shaft?
post a video of the idle it can help us narrow down the reason.
timing, valves, fuel delivery, spark and emissions all have the possibilty of making this issue.
Old Jan 11, 2011 | 11:52 AM
4Crawler's Avatar
How did you set the timing? Test jumper installed and did the idle/timing change w/ the jumper install?
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
Old Jan 11, 2011 | 11:55 AM
Love the scan tool!!!!
Old Jan 11, 2011 | 07:51 PM
84sdyota's Avatar
Will video tomorrow it has good compression on all cylinders it is giving me a code 11. I adjusted the timing and it's running better but when I push the gas pedal Down it lags a little then goes up and floored it only goes to 4000 rpms.
the1998sr5
15
Jul 14, 2020 08:35 PM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
karbin
Jul 5, 2015 11:37 PM
