Sponsored by: CARiD
mechanical issues with 6" lift on 1999 4runner
Old Feb 8, 2018 | 07:04 PM
seklmk's Avatar
1999 toyota 4runner limited with awd option and with automatic transmission.. also a separate problem, can anyone tell
me the correct part no's for replacing the shift solenoids, and how much do they affect the idling, misfiring etc problems
that I also have.. I feel somewhat ashamed that this is actually my 5th 4runner.. although, it is my first 3rd gen... PLEASE
HELP...
THANKS!!!
Old Feb 9, 2018 | 08:53 AM
RAD4Runner's Avatar
Sorry our crystal ball is broken.
Please see signature.
Originally Posted by seklmk
...I feel somewhat ashamed that this is actually my 5th 4runner.. ...
You should be proud to have had 5 4Runners. Heck I only have one, and am proud of, and happy with, it.
Old Feb 9, 2018 | 10:45 AM
L5wolvesf's Avatar
I keep polishing my ball but I can't see what isn't there.
A problem (or 3) well-stated is almost solved.
Old Feb 13, 2018 | 08:40 AM
thefishguy77's Avatar
HELP...
THANKS!!!
Ok I'm going to take a shot at this. Your asking about shift solenoids and how much they affect miss fire, and ignition problems? They really shouldn't affect them at all. Does your 4runner have any codes right now? Miss fire??? If so solve that problem. Maybe its due for plugs wires and coil packs. It was a quick job on my wife's 98 limited. It helped hers shift better, probably because it was now running on 6 cylinders again.
Is your rig is not shifting in to a specific gear? Will it do it manually, shift lever? Does it not want to up shift, down shift, maybe just a particular shift, ie downshifting out of overdrive?
You need to give us a lot more information to help you.
Old Feb 13, 2018 | 04:50 PM
seklmk's Avatar
shift solenoid
yes, the error code is P0753, it shifts manually, everytime i come to a stop I must shift into low, and then when
i start acclerating i shift into 2nd which then almost instantly shifts into drive... when it does hold it in 2nd gear
it rips... otherwise it sputters
Old Feb 13, 2018 | 05:04 PM
seklmk's Avatar
and I also had to replace the MAF sensor
Old Feb 13, 2018 | 07:38 PM
So tour assuming it has a misfire because of the sputter, i can see that idea.
I assume you have pulled apart an automatic transmission before.
If so this is a good start for info on parts
https://www.rockauto.com/en/catalog/...+solenoid,8476
Old Feb 16, 2018 | 04:55 PM
seklmk's Avatar
misfire, erratic idle, no power...
so, are you saying that all of these issues are related to the automatic trans?? and that it has to be rebuilt
to fix these problems??
Old Feb 16, 2018 | 04:56 PM
seklmk's Avatar
actually i shouldn't have started out with a 6" lift issue.. that is the last of my problems...
Old Feb 24, 2018 | 03:26 PM
seklmk's Avatar
Minor issue was the lift but regarding the loss of power rough idling issue..
Back to the KISS method .. $20 set of new spark plugs took care of everything
cmart808
Feb 2, 2018 05:53 PM
littleecker
Jan 29, 2018 11:57 AM
cmart808
Jan 28, 2018 10:38 PM
DoubleSea
Dec 5, 2017 08:27 PM
red-daggs
Nov 16, 2017 04:40 AM
