Sponsored by: CARiD
Leafsprings from 4Runner fit 1st Gen truck?
Old Mar 28, 2017 | 03:40 PM
phillipec94's Avatar
Will factory rear leaf springs out of an 87 4runner work as rear for an 83 pickup?
Old Mar 28, 2017 | 05:07 PM
dropzone's Avatar
Fossilized
they should but 4Runner springs tend to be flatter since they have had the weight of the top on them over time causing a saggy butt syndrome
79-88 Toyota 4wd Rear 20.5/27.5 long 2 3/8" wide 18mm/18mm or 14mm/18mm spring eyes.
Originally Posted by dropzone
63" Chevy rear spring Conversion FAQ
Toyota Rears Up Front (RUF) FAQ
Front Spring Hanger Placement: (when using longer than stock springs like Trail Gears)
some of the following info is from this spring FAQ
Spring Definitions
explained: --Link also has a spring rate calculator that is pretty cool
**Awesome Link for Spring Info: **http://littlekeylime.com/MrN/mrnimages/leaf_springs.png
Old Mar 28, 2017 | 05:22 PM
so would be recommended to do? I have an 83 pickup id like to build a little. I have an 87 4runner for parts. 83 in ruff shape. Rear leafs are completely broke in half.
Old Mar 28, 2017 | 05:31 PM
dropzone's Avatar
Fossilized
you can swap them, i have no clue what the conditions of your 4Runner springs are. free parts and it will only cost you time..
Old Mar 28, 2017 | 05:59 PM
Will it sag to much?
Old Mar 28, 2017 | 07:08 PM
So far into this. They are the same length. However the front shackle bushings are different sizes. Now need to find custom bushings or some that will work..
Old Apr 1, 2017 | 12:00 AM
wyoming9's Avatar
Red face
It might be worth your while to just buy new springs and be done
I have learned used springs are more frustration at least for me
Simple to move spring hangers with the springs
Then there is the fact it is all most impossible to get the bolts out of the metal sleeve in the bushing
Old Apr 1, 2017 | 04:19 AM
dropzone's Avatar
Fossilized
notice in the spring info I posted that it showed 18mm and 14mm bushing sizes..
Old Apr 3, 2017 | 05:48 AM
I did not notice. That helps out a lot. I cannot seem to find bushings that will work with the size im trying to work with. I will more than likely have to just get new springs.
Old Apr 3, 2017 | 05:50 AM
I think im am beginning to understand the same frustration lol.
Old Apr 3, 2017 | 12:48 PM
wyoming9's Avatar
Red face
The really bad thing about used springs is there is no good way to preload the springs till you put them in and have them all torqued down.
Then you find one is completely flat with two friends standing in the bed while the other is some what ok.
All this after fighting to get the original ones off.
Old Apr 4, 2017 | 07:15 AM
Right. my biggest thing at the moment is $$.
I just was gonna try to give the 4runner springs a shot. just for the time being. the truck itself will not be on the road for a bit.
OnMy3rdTac
Apr 15, 2011 12:12 PM
bikedave99
Mar 9, 2010 01:53 PM
animalbmx
Jun 4, 2007 08:17 AM
Toyofast
Feb 15, 2006 07:14 PM
