Sponsored by: CARiD
Gas gauge problem
Old Feb 10, 2011 | 09:31 AM
pumba1239's Avatar
Gas gauge problem
So I created a thread about some issues I have with the new runner but while at work I remembered another problem. My gas guage doesn't work. Its a 94 runner 3.0 auto. Any help is apreciated. Thanks
Old Feb 10, 2011 | 09:44 AM
xxxtreme22r's Avatar
define not work. Couple issues that it can be depending on what the gauge is doing.
Old Feb 10, 2011 | 09:51 AM
pumba1239's Avatar
guage isnt doing anything just sits at empty. gas light works though
Old Feb 10, 2011 | 03:05 PM
pumba1239's Avatar
Anyone with any ideas?
Old Feb 10, 2011 | 03:12 PM
camo31_10.50's Avatar
it came unplugged....
Old Feb 10, 2011 | 03:35 PM
swampfox's Avatar
You can unplug the sending unit at the tank and check for power at the end of the plug. If the wiring and gauge are good the test light will light up an the gauge will change position. This will tell you if it is a bad sending unit or a wiring /gauge problem. This works on older trucks without the pump in the tank. I have not tried it on the ones with the fuel light and a fuel pump in the tank ,but I think it will work.
Old Feb 10, 2011 | 04:03 PM
see my build thread, in what I had to do with mine. Same thing sat at empty, almost bought a new $100+ unit, didn't have to.
Old Feb 11, 2011 | 03:53 AM
pumba1239's Avatar
thanks ill be checking that for sure once it gets a little warmer, i thought i read some where that you have access to the sending unit and pump by removing the back seat lifting the carpet and removing the access door?
Old Feb 11, 2011 | 05:27 AM
2+2=4Runner's Avatar
yeah, its true, toyota thinks of everything! the access panel is there, 7 or so little screws to remove and the top of the tank and all wires and access to the fuel pump are right there! its on the passenger side, at least on my 88 4runner its there.
Old Feb 12, 2011 | 06:55 PM
korkskru's Avatar
i have an 89 sr5 3.0, my gas gauge works when the tank is filled up, then when the fuel level goes down a bit it falls to empty. i have been just watching mileage to fill back up. any rhyme or reason for this? fairly new to playing with toyotas, other than my '99 tacoma i had. i think i have most of the other bugs worked out for now. thanks brian
Old Feb 13, 2011 | 03:23 AM
pumba1239's Avatar
hey brian read xxxtreme22r build thread for his pickup, he had an issue and it turns out that the connector was corrioded off the sending unit, my gauge doesnt at all, id check the connector and wiring for it. you can access the pump and sending unit from under the passenger seat. there is a access plate remove the screws and you have access.
Old Feb 13, 2011 | 05:06 AM
yours is a different problem then the original posters. Problem with the gauge like you describe is almost always the sender itself. Since you can read full and not half or empty your connections at the gauge are fine.
There is an article somewhere that describes what the cause your problem is. I'll have to find it.
Old Feb 13, 2011 | 05:48 AM
korkskru's Avatar
thanks guys
Old Feb 13, 2011 | 07:24 AM
Andrewb1369n's Avatar
Yeah mine does the same thing as korkskru's. It shows full when i fill it up but it goes down and shows empty and only lets me put 5 or 6 gallons in when it shows completely empty.
Old Feb 25, 2011 | 08:22 AM
kscanuck785's Avatar
same problem
yeah, I do have the same problem on my 89 4runner...after it's goes pass 1/2 tank, it falls down to empty...
any ideas or links to that same problem on here?
Old Feb 25, 2011 | 08:33 AM
Um your in one?? anyway Found that other article but seem as though the quotes in it go to a deleted thread or something. but info is still there.
https://www.yotatech.com/forums/f116...runner-199822/
Old Feb 25, 2011 | 08:46 AM
4Crawler's Avatar
Mine used to do that, new sender fixed the problem. Suspect mine was the result of the PO owner installing a new battery backwards before I bought the truck. See below for some testing/repair ideas:
- http://www.4x4wire.com/forums/showfl...&Number=924528
Have head of folks repairing the resistor strip if it is not damaged too bad.
Old Feb 25, 2011 | 08:49 AM
I guess I wanted to know where that one ^ was at
Charecter1
Nov 6, 2023 10:08 AM
gary4runner
Sep 24, 2015 12:53 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
Poncho0206
Jul 10, 2015 06:21 PM
Jnkml
Jul 6, 2015 01:20 PM
