Sponsored by: CARiD
can i turbo my v6?
Old Jul 5, 2010 | 02:49 PM
92toyrunner's Avatar
can i turbo my v6?
hey guys im new to the toyota world! but im falling fast! i have a 92 4runner and i was wondering if these little v6's will handle any boost and stay together?? what do you guys think?
Old Jul 5, 2010 | 02:52 PM
xxxtreme22r's Avatar
the 3.0's can bearly hold together on their own. I would say, don't do it,
but with enough fab work you can turbo anything. Not sure if there is any low compression pistons for the 3.0 though.
Old Jul 5, 2010 | 02:55 PM
here you go:
https://www.yotatech.com/forums/f116...n-3-0-a-81366/
https://www.yotatech.com/forums/f116...71/index3.html
http://www.pirate4x4.com/forum/showthread.php?t=39571
Old Jul 5, 2010 | 04:14 PM
What are the weak pionts of the engine? I know they have headgaskets issues..
Old Jul 5, 2010 | 04:15 PM
mainly head gasket issues due to the exhaust crossover pipe. add a turbo your talking even higher exhaust temps.
Old Jul 5, 2010 | 04:52 PM
peow130's Avatar
Well if he turbos it, he'll be getting headers for certain.
And most likely they'll be custom
Old Jul 5, 2010 | 06:55 PM
Hmm? So what's the problem with the crossover pipe? How is it causing gasket issues? Too much EGT's?
Old Jul 5, 2010 | 08:10 PM
tc's Avatar
tc
Crossover is really tight to the head back in that corner.
Supposedly, the "V" in 3VZ-E means it was built for forced induction ... I DO know the bottom end on these motors is pretty stout.
Big problem is where do you put the turbo.... No room in the engine bay, and it gets hot enough in there already ...
Old Jul 5, 2010 | 08:29 PM
Tofer's Avatar
Sponsor
supercharged 3.4 would be way easier
Old Jul 5, 2010 | 08:51 PM
az4x4runner's Avatar
How did you find that out? What does the Z stand for?
Old Jul 5, 2010 | 09:19 PM
peow130's Avatar
Could do like the cummins and have it right off the manifold/header and then to a intercooler?
that would certainly cool the engine down wouldnt it?
Old Jul 6, 2010 | 05:32 AM
tc's Avatar
tc
Originally Posted by razed
i was bord and found this: http://en.wikipedia.org/wiki/List_of_Toyota_engines
so 3vz-e is 3rd generation VZ engine
a little more digging and found toyota had a "V" engien which was a V8 so it appears they made the "Z" to mean 6 cylinders so a VZ is a V6 and there is a 1VZ and 2VZ if it matters
To my knowledge, there is no relation between the V block and the VZ block ... by your logic, the 3RZ in the Tacoma would be a 6 cylinder (or 2 cylinder) version of the 22R ... which it's not ...
Note that all numbers aren't used in production (at least in truck applications). For example, there is a 20R and 22R, but no 21. The 1VZ and 2VZ never saw production.
Old Jul 6, 2010 | 06:14 PM
Well thanks guys! I got my heads back from the machine shop and he said don't mess with a turbo as well. Guess I'll just leave it alone I LOve turbos so I can't help myself! I'm also building a explorer with a twin turbo mustang engine
TheBFA
Feb 15, 2020 06:55 AM
CPD4runner
9
Nov 5, 2017 06:01 AM
voiddweller
53
Feb 1, 2016 05:46 AM
voiddweller
Sep 28, 2015 11:21 PM
viesail
Sep 21, 2015 06:00 AM
