Sponsored by: CARiD
95 4Runner,new owner rear window switch question...
Old Apr 12, 2008 | 07:26 PM
scootr68's Avatar
I just purchased a 95 4Runner SR5 V6 with 167,000 miles. So far it's been an awesome truck but has one little issue. The rear window goes up and down great using the console switch, however when using the gate key switch is does nothing at all. I took the interior cover off to look at the switch,disconnected it and cleaned it out...still nothing. Has anyone else ran into this? If so what was the common issue? Thanks all!
Old Apr 13, 2008 | 02:03 PM
Ohio4R's Avatar
Its probably the switch inside of the lock hole.
Old Apr 13, 2008 | 02:18 PM
SigEp4Runner's Avatar
My 91 goes down but not up with the key! Its really annoying having to get back in and turn it on just to role it up. I havnt looked into fixing it yet though.
Old Apr 13, 2008 | 04:11 PM
scootr68's Avatar
That is starting to be my guess. I've checked all over other than a dealership for it...not even Fleebay has any key switches.
Old Apr 13, 2008 | 05:39 PM
RobD's Avatar
Before you assume it's the key, have you checked the wiring for power?
Old Apr 13, 2008 | 05:45 PM
scootr68's Avatar
Well, I have a tester with a light...I put them in the plug going to the key switch and nothing happened. Now I'm pretty mechanically inclined except when it comes to electrical issues. I may have not tested it correctly at all.
Old Apr 13, 2008 | 06:22 PM
4Crawler's Avatar
A lot of the switches for the rear window make conntections to ground when activated, so a simple test light may not show anything. A volt or ohm meter is a better tool:
http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
Old Apr 13, 2008 | 06:27 PM
scootr68's Avatar
I actually just purchased one so it looks like I will try that this week.
warrenjcarlson
Jul 22, 2016 11:47 AM
voiddweller
19
May 2, 2016 09:10 PM
Corey
Jun 19, 2002 11:06 AM
