Sponsored by: CARiD
1988 Toyota vacuum problems
Old Dec 16, 2011 | 05:32 AM
BigBodyFord02's Avatar
I have a 1988 22re I just completely rebuilt. Aluminum Nippon head, bored .30 over, LCE performance intake manifold (upper and lower), LCE big bore throttle body, Bosch 200 cc injectors, RGV Stage 2 cam and LCE cold air intake. I now have a high idle when it fires up. I'm pretty sure I have vacuum problems. Does anyone know which vacuum lines I can delete and which ones I need to keep? Also do I need to run all the EGR stuff? Thanks
Old Dec 16, 2011 | 06:00 AM
waskillywabbit's Avatar
Welcome to Yotatech
Search for vacuum diagrams as there are numerous posts about the topic.
www.ncttora.com/fsm
:wabbit2:
Old Dec 16, 2011 | 07:50 AM
I've looked at several diagrams but they rarely show in detail which ones can be deleted and which ones that have to remain hooked up
Old Dec 16, 2011 | 08:16 AM
rgnavarr's Avatar
Like he said before... SEARCH! Everything that has been wrong with my truck has already been mentioned in threads years ago. Having had significant vacuum issues with my 22r in the past, get a can of carb cleaner and start spraying areas of possible vacuum leaks. The engine idle will increase if there is a leak. The fact that 22re's dont have many vacuum lines it might be a bad seal on your intake manifold. FYI, keep the EGR if you're taking it through emissions, just block it off afterwards for better performance. This and much more information is buried in threads from the past.
Old Dec 16, 2011 | 08:20 AM
4Crawler's Avatar
One that can be deleted:
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/10.html
Most of the other lines are pretty useful, suppose you could delete the power steering idle up valve:
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/11.html
For the others, read the FSM sections (like the EFI, emissions control, AC, steering, etc.) and understand what the lines and devices do and then you'll know how they should be hooked up and if you could delete them. You won't find one overall vacuum hose diagram in the FSM nor any listing of what can be deleted.
Old Dec 17, 2011 | 05:53 AM
Thanks. Gonna check some of those out and see if I can get this thing running any better. I'm still trying to see just how much power I can get out of this little 4 cylinder
Old Dec 17, 2011 | 07:15 AM
Bassmastry101's Avatar
There was a post this morning that you might be interested in.
https://www.yotatech.com/forums/f116...outing-246150/
6th Gear
19
Dec 10, 2019 07:31 AM
JF9243176
Oct 8, 2017 04:21 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
JF9243176
Jun 24, 2015 04:53 AM
