daytime running lights
Old Oct 8, 2006 | 04:40 PM
rugerm44's Avatar
How do you turn off the daytime running lights on an 06 crew cab?
Old Oct 8, 2006 | 05:18 PM
86SR522REEFI's Avatar
?????? toyota doesnt have a crew cab. and you usually cant shut drls off anyways. Maybe searching or putting up more info would help.
Old Oct 8, 2006 | 05:27 PM
NPE701's Avatar
I think he meant four-door Tacome or Tundra. Can that be considered a crew-cab?
And in regards to DRLs - I'm sure it is possible to turn them off. Need to use search first and then follow the directions.
Old Oct 8, 2006 | 07:13 PM
Elton's Avatar
ya need more info than that
Old Oct 9, 2006 | 05:06 PM
rugerm44's Avatar
Never Mind!
Old Oct 18, 2006 | 07:17 AM
dropzone's Avatar
Fossilized
Yes, Toyota has a crew cab, sometimes called a double cab or 4 door. I own a 2005 and in my overseas adventures have seen 3 different styles of toyotas that could be considered as a 'crew cab'
And yes there is a way to override the DRL. My 05 Camry came with it from the factory. I have seen several trucks with the DRL turned off, just need to figure it out. Will post it when I have the info....it is possible....
Old Oct 19, 2006 | 02:37 AM
rugerm44's Avatar
I called it a truck I hope that was correct.I have owned them since 1978.Thanks ocdropzone for the more adult reply.I dont have the time to argue over 4 doors.Thanks again.
Old Oct 26, 2006 | 08:50 AM
Sharp4runr's Avatar
For the 4th Gen 4runners, you can take your truck into the dealership and they can turn off DRLs with a scan tool. It takes just a few minutes to do. The hard part is convincing the dealership they can do it and doing it for free.
Old Oct 26, 2006 | 09:38 PM
fireteacher's Avatar
heres one for the late 3rd gens. maybe its the same or it will help get the bal rolling.
i always have called 4 door trucks crew cabs. a "work crew" type of truck. ford chevy or yota, CREW CAB!!
EDIT forgot the link!
https://www.yotatech.com/forums/show...hlight=drl+mod
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
Johntom240
7
Jul 13, 2015 12:18 AM
madxman21
Jul 9, 2015 10:26 AM
