91 Gas Necessary
Old Sep 22, 2006 | 01:54 PM
sbikes's Avatar
91 Gas Necessary
I found some specs for the 05+tacos and saw that they recommend 94 gas. I wasn't to excited about this since i just ordered my 07 taco and gas isn't the cheapest thing to buy these days! I was wondering if anyone is running there 05+ taco on 87 (unleaded). Will it harm my truck or affect anything??
Old Sep 22, 2006 | 02:26 PM
Rivalred's Avatar
You do not need 91... I noticed no difference from 87 octane to 94 I even used when I have my Tacoma. Just goos ole 87 octane and you will be fine.
Old Sep 22, 2006 | 02:40 PM
sbikes's Avatar
Good to hear, so i guess you haven't noticed any pinging sounds coming from your engine. I heard putting lower octane (then recomended) can take its toll on the engine over time since it takes less compression to combust.
Old Oct 27, 2006 | 09:03 AM
4-RUNNIN' FREAK's Avatar
I use w/e I feel like at that moment... Usually 87. I notice NO performance gain from 87 or 94 octane.
Old Oct 27, 2006 | 01:32 PM
Jared's Avatar
Recommended, but not needed at all. The computer will adjust for any reasonable octane. I say reasonable, because it probably can't take 115 racing or anything like that.
Old Oct 29, 2006 | 06:07 AM
<<<<'s Avatar
94 octane? I'd never use anything higher than 91, unless you want waste money.
Old Oct 30, 2006 | 04:25 AM
yrffej's Avatar
on the '05 and newer tacoma, we have a knock sensor and vvt. you can run almost any grade octane. but, low octane will cause the sensors to retard timing (reducing a little power efficiency, and mpg). i have an auto trans, and it was noticable with the cruise control on.... trans would down shift, sometimes multiple gears when not necessary. i started using the mid grade octane, and on the same roads the down shifting has greatly reduced. you may not notice the engine timing being retarded when driving a manual trans...
larrys93pickup
Sep 17, 2015 07:05 PM
Gone Fission
Sep 14, 2015 08:33 PM
AlexJet
Sep 14, 2015 09:00 AM
gp66
Sep 14, 2015 12:10 AM
Boomer8404
Sep 10, 2015 09:01 AM
