will tires these fit.
Old Feb 27, 2006 | 04:32 AM
87rustbucket's Avatar
Just wondering if 33" 9.5 BFG mud terrains will fit my 87 with minimal cranking of the torsion bars. The back has no bed so thats not a prob. Plz respond soon because hes sellin them cheap. Thanks
kev
Old Feb 27, 2006 | 04:47 AM
Intrepid's Avatar
Depends on how much trimming you want to do to the front fenders and firewall.
Personally, I think you need to spend your time and money cutting out and replacing the rusty sections of the frame. Make it driveable, wheelable, and inspectable, then worry about tires, etc.
Old Feb 27, 2006 | 05:09 AM
k, thanks for the info- and i agree with the make it inspectable thing too. Oh well...
Old Feb 27, 2006 | 09:24 AM
tc's Avatar
tc
Should fit no problem. Got 33x10.50 on my second gen with no lift (not even tbar crank). Definitely a pizza cutter!
Old Feb 27, 2006 | 11:12 AM
but will it fit on my 1st gen? im confused
Old Feb 27, 2006 | 04:16 PM
BeaterToyota's Avatar
They will fit. My junk has been running 32X10.50 Super Swampers for like 3 years with a 1.5" ball joint spacer, although the tires fit just fine before the spacer was installed. Those tires measure about 3/8" shorter than the BFG 33"s, but they're a bit wider. You'll have no problems.
I'm about to do a SAS, so I threw my new 36x12.50 Swampers on my junk with just the 1.5" BJ spacers and the factory torsion bar setting. It works fine on-road, but there isn't enough clearance like this for off-road.
Old Feb 28, 2006 | 01:04 PM
V_Runner's Avatar
Banned for stupidity
i wish i had wheels like thar
Old Feb 28, 2006 | 02:13 PM
wi wish i had a truck like that-btw vin, dont those rims look alot like my old ones..
Old Mar 3, 2006 | 03:51 PM
will those tires fit for shure with full turn and slighly trimed fenders-might buy them in two days
Old Mar 4, 2006 | 03:55 PM
anyone know positivly for my truck?
Old Mar 4, 2006 | 04:13 PM
They should fit.
However, every truck is different. My '94 and my '88 have NEVER had the torsion bars adjusted since they left the factory, but the '88 came with about 3/4" more "lift" on them than my '94.
I think the tires you're looking at would need some torsion bar cranking to fit on my '94, but I could guarantee they would fit my '88 (even without the BJ spacers that are currently on it.
Old Mar 4, 2006 | 04:21 PM
at full wheel turn?
Old Mar 4, 2006 | 04:28 PM
My 32x10.50 Swampers fit without any rubbing at all. They are almost the exact same size as a BFG 33x10.50, so 33x9.50 should be no problem.
Old Mar 4, 2006 | 04:33 PM
k-thanks- kant beat the price for em- at least 80 percent left only 200$ w/ rims
Old Mar 4, 2006 | 04:35 PM
Go for it!
Old Mar 4, 2006 | 04:37 PM
btw- were the rims pictured on ur truck above originally chrome? and what brand are they?
Old Mar 4, 2006 | 04:46 PM
Nope, they came black. They are "Cragar Soft 8" wheels that I got from Summit Racing. They were $157 for 4 rims, delivered to my house.
Old Mar 4, 2006 | 04:56 PM
these are my old rims- american racing im givingg them w/ the tires to V RUNNER
im putting on big fender flares so ill probably be cutting out the fender rust. then i gotaa through in the new fuel pump through it on a trailor and bring it to my bosses yard, fix the rear crossmember, make a wood flat bed, repaint it and fix some exast leaks- all by the end of march when i can get my lisence. And thats all i got to do!
foampile
Dec 18, 2022 01:29 PM
HotNotch
Oct 8, 2015 06:51 AM
zombie_stomp
Aug 17, 2015 05:29 PM
andrewtexas123
Jul 23, 2015 11:22 AM
yourrealdad
Jul 21, 2015 11:13 AM
