Where does this wire go (pic)? 93 4x4 DLX Pickup
Old Feb 28, 2018 | 03:56 PM
Indetrucks's Avatar
Question Where does this wire go (pic)? 93 4x4 DLX Pickup
Found this wire behind the bench seat. The connector was plugged into another connector coming out from under the carpet, near the seat belt.
Is it for a seat belt warning/reminder? Where does the stripped wire end attach to?
Thanks all
Attached Thumbnails Where does this wire go (pic)? 93 4x4 DLX Pickup-img_20180228_164230069.jpg
Old Mar 2, 2018 | 07:02 AM
Indetrucks's Avatar
Anybody have a similar truck they can check? Pretty please?
Old Mar 2, 2018 | 07:36 AM
RAD4Runner's Avatar
Has to be the seatbelt buckle switch that P.O. ripped off.
Wouldn't it be more accurate and quicker if you inspected your seatbelt buckle switch wiring?
Do you get a seatbelt warning when you unbuckle you seatbelt while engine is running?
Old Mar 2, 2018 | 10:27 AM
highonpottery's Avatar
I want to say seat belt idiot light, I think my 93 DLX has one down there too.
Old Mar 2, 2018 | 03:50 PM
scope103's Avatar
The wires for the seatbelt switch should be B and W-B. Your picture makes the wires both look G. Are they actually that color? The connector looks right.
Old Mar 4, 2018 | 01:04 PM
Drewandhis89Yota's Avatar
Old Mar 4, 2018 | 08:01 PM
RAD4Runner's Avatar
Originally Posted by Drewandhis89Yota
And that's from same model-year? Toyota wire colors are confusing.
Old Mar 4, 2018 | 09:58 PM
Co_94_PU's Avatar
Decades of filth, yuck! Every body above need to take a scotchbrite and grease remover to those wires..
Don't think I have images of my wires. Wasn't much worried about reminder chimes..
(Just checked not seeing the belt reminder wires)
There aren't a lot of options under the seats, it is either belt reminders or oxygen sensors and that's not oxygen sensors..
Old Mar 4, 2018 | 10:20 PM
RAD4Runner's Avatar
Yanked mine out years ago. When I was in the Navy we were told our life insurance would not me paid if we died of a car accident while not wearing a seatbelt. Didn't need a stupid buzzer for that.
Old Mar 5, 2018 | 05:08 AM
Indetrucks's Avatar
Thanks for the responses and pics, yep.. that looks like it. I'll have to see if I can find the other end of the wire under there.
I looked for a bit, it must be under the carpet somewhere.
Old Mar 5, 2018 | 05:33 AM
RAD4Runner's Avatar
It should run behind the rail where the front seat mounts on to the door threshold, to the connector behind the left-side kick panel.
Old Mar 6, 2018 | 06:44 AM
Indetrucks's Avatar
Thank you, I'll be checking it this weekend.
Old Mar 6, 2018 | 07:05 PM
RAD4Runner's Avatar
Old Mar 6, 2018 | 07:16 PM
Co_94_PU's Avatar
Your image shows a female socket, user provided image of latch shows female socket, you say in the first post it was plugged in... Your loose wires go inside the buckle/latch, probably not easily repaired...
Old Mar 6, 2018 | 07:22 PM
RAD4Runner's Avatar
Originally Posted by Co_94_PU
...... Your loose wires go inside the buckle/latch, probably not easily repaired...
This^^^ Once confirmed it is for the seatbelt, which I really think it is, I'd just leave it alone, unless O.P. needs a reminder to put seatbelt on.
Old Mar 7, 2018 | 06:56 AM
scope103's Avatar
Which would also explain the (lack of) color.
VegasNaturist
Jul 14, 2013 12:42 PM
qqq6677
Apr 11, 2013 07:14 PM
igotit
Dec 12, 2011 02:16 PM
BigWavePaul
Jun 15, 2008 02:06 PM
ChickenLover
Jun 6, 2004 05:56 PM
