Where does this wire go (pic)? 93 4x4 DLX Pickup
1 Attachment(s)
Found this wire behind the bench seat. The connector was plugged into another connector coming out from under the carpet, near the seat belt.
Is it for a seat belt warning/reminder? Where does the stripped wire end attach to? https://cimg2.ibsrv.net/gimg/www.yot...0cc57e720a.jpg Thanks all |
Anybody have a similar truck they can check? Pretty please?
Originally Posted by Indetrucks
(Post 52392146)
(Post 52392282)
Is it for a seat belt warning/reminder? |
I want to say seat belt idiot light, I think my 93 DLX has one down there too.
The wires for the seatbelt switch should be B and W-B. Your picture makes the wires both look G. Are they actually that color? The connector looks right.
Originally Posted by Drewandhis89Yota
(Post 52392505)
(Post 52392530)
And that's from same model-year? Toyota wire colors are confusing.
Don't think I have images of my wires. Wasn't much worried about reminder chimes.. (Just checked not seeing the belt reminder wires) There aren't a lot of options under the seats, it is either belt reminders or oxygen sensors and that's not oxygen sensors.. |
:) Yanked mine out years ago. When I was in the Navy we were told our life insurance would not me paid if we died of a car accident while not wearing a seatbelt. Didn't need a stupid buzzer for that.
Thanks for the responses and pics, yep.. that looks like it. I'll have to see if I can find the other end of the wire under there.
I looked for a bit, it must be under the carpet somewhere. |
(Post 52392546)
(Post 52392549)
It should run behind the rail where the front seat mounts on to the door threshold, to the connector behind the left-side kick panel.
Your image shows a female socket, user provided image of latch shows female socket, you say in the first post it was plugged in... Your loose wires go inside the buckle/latch, probably not easily repaired...
Originally Posted by Co_94_PU
(Post 52392724)
...... Your loose wires go inside the buckle/latch, probably not easily repaired...
(Post 52392724)
