What is this? i made a whoops
Ok, so i did something stupid. Was adjusting the valves in my 22re and left a ratchet on the crankshaft pulley when i started the engine.
It took a little to notice but the ratchet spun up and broke a plus off my motor. The plug goes under my EFI, not sure what it is though. Thats what i need to know. I drove the truck home (i was at a buddy's) with the plug unhooked, and it only hesitated when revved quickly. the ratchet snapped the plug off and ripped it off the wire. So, what is this exactly? Where's the best place to get one?
hmmm whatever it is it makes my check engine light come on and it has a slight hesitation when you rev it. I didn't drive it today just because i wanted to know what it was before i kept driving it.
you might also want to check that your crankshaft pully is still torqued to spec. I did the same thing once and i busted my fan up and loosened up my crankshaft pully. I ended up having to take the timing cover off and lining up the marks and torqueing it again.
ashamsuddin
17
Jul 22, 2024 03:59 AM
Brodetski
Sep 30, 2015 11:50 PM
