What is this? i made a whoops
Old Oct 3, 2012 | 03:26 PM
Yamiryder's Avatar
Unhappy What is this? i made a whoops
Ok, so i did something stupid. Was adjusting the valves in my 22re and left a ratchet on the crankshaft pulley when i started the engine. It took a little to notice but the ratchet spun up and broke a plus off my motor. The plug goes under my EFI, not sure what it is though. Thats what i need to know. I drove the truck home (i was at a buddy's) with the plug unhooked, and it only hesitated when revved quickly. the ratchet snapped the plug off and ripped it off the wire. So, what is this exactly? Where's the best place to get one?
Old Oct 3, 2012 | 04:00 PM
iliketoyota's Avatar
Junkyard
Old Oct 3, 2012 | 04:01 PM
Yamiryder's Avatar
thats what i was thinking, but what is it exactly? EGR temp sensor?
Old Oct 3, 2012 | 04:06 PM
I wanna say cold start time out switch plug. But probably better to have someone else confirm that. Since you drove it home fine I bet thats what it is.
Old Oct 3, 2012 | 04:12 PM
Yamiryder's Avatar
hmmm whatever it is it makes my check engine light come on and it has a slight hesitation when you rev it. I didn't drive it today just because i wanted to know what it was before i kept driving it.
Old Oct 3, 2012 | 04:49 PM
Vang530's Avatar
ECT aka engine coolant temp sensor that sends temp to the ecu, not for the gauge.
The one on the left is for the cold start injector switch.
Old Oct 3, 2012 | 05:18 PM
Yamiryder's Avatar
thanks! helps a lot. would it be better for me not to drive the truck till i fix this then?
Old Oct 3, 2012 | 09:07 PM
Slowey23's Avatar
It would most likely run the engine a little lean whilst cold but o2 sensor will make adjustment to correct that, don't go thrashing it and I'd say it's ok to drive
Old Oct 4, 2012 | 04:36 PM
Yamiryder's Avatar
It didn't want to start too good this morning so i didn't drive it. I'lll just wait till i get a new sensor before i go back to driving it everyday.
Old Oct 4, 2012 | 04:52 PM
StewsRunner's Avatar
I broke mine off and drove without for a couple days. My only issue was a CEL and a very long crank once in a while.
Old Oct 5, 2012 | 07:12 AM
Yamiryder's Avatar
thats exactly what mine did. It was probably around 45 degrees yesterday and didn't want to run real smooth, so i just didn't run it
Old Oct 5, 2012 | 08:18 AM
buggout95's Avatar
you might also want to check that your crankshaft pully is still torqued to spec. I did the same thing once and i busted my fan up and loosened up my crankshaft pully. I ended up having to take the timing cover off and lining up the marks and torqueing it again.
ashamsuddin
17
Jul 22, 2024 03:59 AM
Davebarbier
Nov 3, 2015 03:28 PM
White Stripe
Oct 6, 2015 10:47 AM
Brodetski
Sep 30, 2015 11:50 PM
