truck got some bad noise
Old Sep 16, 2009 | 02:46 PM
fooboo's Avatar
what is it??
any solution?
and tips about repair??
http://vids.myspace.com/index.cfm?fu...deoid=63225311
Old Sep 16, 2009 | 02:52 PM
Junkers88's Avatar
Sounds like an exhaust rattle.
Check the hangers and bolts.
Old Sep 16, 2009 | 03:12 PM
nhughes's Avatar
cool it and bang out you catylitic converter, any rattle? heat shield maybe? turn up the stereo?
Old Sep 16, 2009 | 10:46 PM
Armalite's Avatar
Ya x2 on the exhaust rattle. My pickup makes pretty much the same noise when i push the gas because one of the hangers broke on the exhaust and is now being held up by bailing wire.
Old Sep 18, 2009 | 06:26 PM
garry#88's Avatar
mine had a bad noise too.but only when my wife was with me. weird huh?
Old Sep 18, 2009 | 06:32 PM
Jay351's Avatar
Check the bracket that bolts the manifold/collector to the trans.
my girls is loose and makes one HELL of a racket when under load!
but it sounds like there is something in the pipes.. I bet the cat is busted.
Lumpy's Avatar
Well they all told you what it was...what did you find?
Old Sep 19, 2009 | 11:25 AM
fooboo's Avatar
i check out my exhaust!!
i saw bracket that is loose!
but i lost my the bolts for the bracket
exhaust.....
Old Sep 19, 2009 | 12:28 PM
22RUCRAZY's Avatar
I had the same prob after a rebuild , scared me until i found the loud broken bracket
Old Sep 21, 2009 | 07:33 PM
fooboo's Avatar
how can i order a new bracket and bolts?
Old Sep 21, 2009 | 07:35 PM
fooboo's Avatar
i find a loose/broken bracket from the pipe
and lost two bolts!! any special order online....
Old Sep 22, 2009 | 04:42 AM
Lumpy's Avatar
Pictures will help, I'm not sure which bracket you are referring to.
Old Sep 24, 2009 | 03:01 PM
fooboo's Avatar
Now i weld my broken brackets...
so it should be ok..but i need a bolts for
special orders!
but PICTURES will be up soon!!
duckhead
170
Nov 13, 2017 06:07 AM
voiddweller
19
May 2, 2016 09:10 PM
camdenbuck
Jul 7, 2015 07:33 AM
Mr.Black
Jun 21, 2015 10:17 AM
