truck got some bad noise
what is it??
any solution? and tips about repair?? http://vids.myspace.com/index.cfm?fu...deoid=63225311 |
Sounds like an exhaust rattle.
Check the hangers and bolts. |
cool it and bang out you catylitic converter, any rattle? heat shield maybe? turn up the stereo?
Ya x2 on the exhaust rattle. My pickup makes pretty much the same noise when i push the gas because one of the hangers broke on the exhaust and is now being held up by bailing wire.
mine had a bad noise too.but only when my wife was with me. weird huh?
Check the bracket that bolts the manifold/collector to the trans.
my girls is loose and makes one HELL of a racket when under load! but it sounds like there is something in the pipes.. I bet the cat is busted. |
Originally Posted by Junkers88
(Post 51230663)
Originally Posted by nhughes
(Post 51230677)
Well they all told you what it was...what did you find? |
Originally Posted by garry#88
(Post 51232551)
i saw bracket that is loose! but i lost my the bolts for the bracket exhaust..... |
I had the same prob after a rebuild , scared me until i found the loud broken bracket
Originally Posted by 22RUCRAZY
(Post 51232906)
Originally Posted by Lumpy
(Post 51232565)
and lost two bolts!! any special order online.... |
Pictures will help, I'm not sure which bracket you are referring to.
(Post 51234712)
so it should be ok..but i need a bolts for special orders! but PICTURES will be up soon!! |
