TPS feeler gauge
Old Oct 1, 2006 | 04:05 AM
Yotapup's Avatar
TPS feeler gauge
Where are you guys finding a feeler gauge for the TPS settings? No one around my area has them.Plenty of feeler gauges but none with the particular sizes.
Old Oct 1, 2006 | 04:54 AM
trythis's Avatar
Have you tried NAPA? They have quite a few. I think I stacked some to acheive thh required thickness.
Old Oct 1, 2006 | 05:30 AM
Yotapup's Avatar
Tried NAPA with no luck. I can't even get the right ones to stack and achieve the right size.
Old Oct 1, 2006 | 05:53 AM
bodo's Avatar
If you're only .001 off either way it's not going to matter.
Old Oct 1, 2006 | 06:17 AM
farmerj's Avatar
About it too.
I think I stacked mine to like .557 or something like that and .889. I'd have to dig them out again.
It's a pretty knife edge setting so if you set the off idle first to just cut in, you should right on the closed throttle setting.
Old Oct 1, 2006 | 06:38 AM
Yoda's Avatar
Yup, stacked them to be close to the desired measurement.
Old Oct 1, 2006 | 06:43 AM
Yotapup's Avatar
Alright, thanks guys! I will give it a try.
Old Oct 1, 2006 | 08:04 AM
Fahrenheit 451's Avatar
I bought a cheap set from Harbor freight and as I remember I was able to get spot on for the measurements. Somewhat frustrating locating/handling all those flipping thin ones so I finally just pulled the ones I needed and relocated them at the top so I can always get back to them easily.
Old Oct 1, 2006 | 08:05 AM
I forgot to mention, while you are at it you might as well do the bolt swap on the TPS. It makes it MUCH easier to do when it is still on the truck. There are various posts on here about it and it only costs a couple bucks. I got all the stuff I needed at True Value.
Old Oct 1, 2006 | 04:06 PM
Yotapup's Avatar
Talking
Lucky Me! stopped by Pep Boys and they had an almost perfect feeler gauge that covers all the way up to a 1.00mm gap.
ashamsuddin
17
Jul 22, 2024 03:59 AM
zanzabar0
Oct 11, 2015 02:56 AM
Jdgarrison
Oct 1, 2015 05:22 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
dbollier123
Sep 29, 2015 05:23 PM
