Temperature gauge reading low
Old Sep 3, 2020 | 01:56 PM
RAD4Runner's Avatar
Originally Posted by Co_94_PU
Oh the block drain, that makes my thermocouple line plenty long enough to use.. I have a three guage setup ...
Originally Posted by MaK92-4RnR
... It tells me the exact water temperature at any given time and even flashes red when it gets over 210..
There you go! Exactly what I want - a more visible alert I could probably hook-up to a beeper, too.
Guys, care to share what system you have and where your sender / thermocouple is mounted?
Old Sep 3, 2020 | 02:44 PM
DavidCharles's Avatar
Mine started to do the same on my SR5 instrument cluster. I read to clean the gauge backside contacts. I removed the cluster and backing (easy to do) then spray the water temp (I did all of them) with electrical contact cleaner. Had a small artist paint brush with long soft bristles I soak with cleaner to get into all the tight spots. It fixed the low reading. Might not work on yours, but at least you'll have clean contacts now.
Old Sep 3, 2020 | 03:37 PM
J94's Avatar
J94
I'm just paranoid about the temp reading because my old truck's temp, a 1992, would read 1/4 on the dash. It was my first vehicle and I didn't know much. Still don't but not afraid to learn. Anyway, that truck had a bad fan clutch and I didn't figure that was causing my intermittent overheating issues until it was too late. Ended up have a spark plug frozen. I put a sleeve in there but I wasn't happy and questioned the truck being reliable at that point.
That being said, I would like my temp gauge to read accurately! Maybe I'll have to do some aftermarket gauges too.
Cesar Telles
Aug 31, 2020 08:33 PM
Barth Farkle
Jun 17, 2020 08:23 PM
Mason Edmison
Jul 7, 2018 08:03 AM
bipolarandproud
Oct 2, 2008 09:39 PM
MonkeyElvis
Nov 14, 2002 11:54 AM
