T.P.S. what is this
Old Oct 1, 2008 | 05:11 PM
keithguts's Avatar
T.P.S. what is this
can some one tell me what the tps does. this is what my mach. told me I needed for my rig.
Old Oct 1, 2008 | 05:16 PM
scuba's Avatar
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
I say READ
But first, you could try searching...ill quit being an ass now, quick test.
Unplug the TPS, if its running bad when it IS pluged in, and better without it pulgged in, its most likely the culprit.
BTW, whats your truck doing, like why did you take it to a mechanic in the first place ?
Old Oct 1, 2008 | 05:19 PM
91Toyota's Avatar
Toilet Paper System...it regulates how much toilet paer you'll need
Old Oct 1, 2008 | 05:43 PM
abecedarian's Avatar
and on a less serious note...
the TPS is the Throttle Position Sensor- it tells the ECU how far open the throttle is so that it can calculate how much fuel to inject. The ECU can also use the TPS to determine whether the throttle is opening quickly, like you're stepping on it hard, and inject some extra fuel like the accelerator pump does for a carburetor, and if the throttle is closing, it'll cut fuel to reduce emissions.
Old Oct 1, 2008 | 05:45 PM
91Toyota's Avatar
Figured since he has like 1400 posts he would know what a TPS is by now
Old Oct 1, 2008 | 05:48 PM
well, you've got 980+ and don't know how to prime an oil pump...
Old Oct 1, 2008 | 05:49 PM
91Toyota's Avatar
LOL...true!
Old Oct 1, 2008 | 05:54 PM
keithguts's Avatar
great answer. Thanks................................
Old Oct 1, 2008 | 05:56 PM
keithguts's Avatar
I'm glad other people answered my ? because you sure didn't. I guess that because you didn't no the answer..............
Old Oct 1, 2008 | 06:04 PM
In 91Toyota's defense, he knows the answer- he spent weeks trying to get a truck running better and has been through the testing procedures and such for the TPS many times. I think he was just trying to be funny....
Old Oct 1, 2008 | 06:09 PM
91Toyota's Avatar
LOL...calm down. Yeah I knew the answer. NO I'm not funny at all. I've played with them many times...lol.
Old Oct 1, 2008 | 06:13 PM
MYFJ6O's Avatar
So if you see foam do you need toilet papaer system or would that be truly an open throttle position
lol
Old Oct 1, 2008 | 06:14 PM
91Toyota's Avatar
LOL...I'm not answering that!
Old Oct 1, 2008 | 06:16 PM
MYFJ6O's Avatar
Old Oct 1, 2008 | 06:23 PM
MYFJ6O's Avatar
TPS really helpful visual aid
40vern
Feb 14, 2019 12:12 PM
xXlGearheadlXx
Feb 28, 2011 04:53 PM
ThatGuy84
May 19, 2010 03:31 PM
