Stainless braided clutch line?
Old Aug 23, 2020 | 08:04 PM
davinm's Avatar
Doing a swap and need to know if anyone knows the fitting that will screw into the master cylinder. The other side will have a 3an male fitting that will connect to a 3an hose down to the slave.
Here's Amazon link with what says is a 3/16 90degree flare to 3an hose. (I'm not worried about other end of hose)
Will this work at the master cylinder side? Or is there a different fitting people recommend to connect to the master?
https://www.amazon.com/dp/B009Q750LC/ref=cm_sw_r_cp_apa_i_WSZqFbG2JXJ7H
Old Aug 23, 2020 | 08:38 PM
muddpigg's Avatar
I’m a bit confused. All fittings are metric at master and slave. So you’ll need M10x1.0 to AN fitting. I’d price out set up you want then compare to Marlin’s braided clutch line.
Old Aug 23, 2020 | 09:13 PM
davinm's Avatar
I'm running a braided line from a t56 slave quick disconnected converted to an fitting on the slave side. So I just need to know what the fitting is at the master side that screws into the master.
I'm not around my 4runner for next couple days and could not remember it. I'm used to wilwood masters lol.
Which is why I was asking if that link would work.
Old Aug 23, 2020 | 09:16 PM
davinm's Avatar
Amazon Amazon
So that's what I need for the master cylinder side? If so you're awesome!!
Old Aug 24, 2020 | 05:42 AM
MaK92-4RnR's Avatar
I did this on my 1st gen 4Runner. just had a local shop make the lines to my specifications and I removed the entire hardline from the master to the slave.
Old Aug 24, 2020 | 06:17 AM
davinm's Avatar
I can do that as well. But the m10x1.0 is the fitting at the master?
Just needing to double check. This is LS swap going in with a different trans than the r150
Old Aug 24, 2020 | 06:23 AM
MaK92-4RnR's Avatar
correct, it's m10x1.0 at the master.
Old Aug 24, 2020 | 01:27 PM
davinm's Avatar
Thank you for your direct answer. It's like pulling teeth asking this on another Facebook group. All I get is why the ˟˟˟˟ do you wanna do that. Etc etc just 3.4 swap it on a question where I just need to know what fitting is lol
otravacaine
Sep 20, 2018 03:36 PM
bobjohnson2121
May 7, 2014 10:29 AM
California
Feb 17, 2012 12:58 PM
jtcessna
Jan 7, 2010 04:21 AM
AKennedy87
Jan 8, 2006 02:25 PM
