rear window
rear window
Noobs here for 4runner Gen 2 version
The rear window intermittent stop working.
Looked for a fuse block but nothing for the windows. Checked engine and kick panel blocks but no fuse
Took back panel apart check the connectors and lubed the rails and connector still won't work. The one other time it did this. We drove it than it stared working.
Any help please
Any help please
Just what year ??
your talking about the hatch window it seems .
It does not work from either the console switch or the switch in the hatch.
Have you checked for voltage at console switch.
While you had the cover why did you not check the motor by applying power to it direct from a 12 volt DC source??
One of the locks or safety switches could have failed.
The switch itself in the console.
Broken or damaged wires going into the hatch.
Sorry it a 94
Rear hatch and console swith both not working
As of right now can't open the rear unless I do it from inside to get to the motor
Didn't think at the time to check the motor
When I had it apart the wires all looked good and I lube all the rails and gears with light grease.
I have to get it apart this weekend and try the 12v to the motor
Just what year ??
On Post #185/186 https://www.yotatech.com/forums/f199...l#post51722787 I have some info that works for me. 90-95 are very similar.
I had the same problem. Mine turned out to be the rear wiper.
Try here http://www.4crawler.com/4x4/CheapTri...CommonProblems
My buds did similar to you plans on building later model 4rnr from parts of his 80-81 built truck. By far a better option than selling rig then sourcing parts to built 4rnr. Will save paying twice for same/similar parts.
Charlie Mike Airborne
if it happens simotaneusly to the console switch and gate key, and both up and down, i would look into the rear wiper. when it stops working, pull the header trim off and test the park contact at the plug. mine read high, and would only work sometimes and a little better when i parked itby hand, but it ohmed fairly high. use white notebook paper to clean the contacts only and make sure it is still lubed when you are done..
Jun 1, 2021 01:51 PM
sabine
Jul 18, 2015 03:59 PM
icentropy
Jul 14, 2015 10:23 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
Jul 6, 2015 04:07 AM
