Questions:
Old Oct 9, 2018 | 11:59 AM
grousehunter 61's Avatar
Questions:
I had to pull the intake air chamber to get to a leaking valve cover , passenger side I am trying to get it back together and the reed valve is giving me nothing but problems. This was all put back on the motor while it was out and easy to get to. The egr valve isn't even hooked up to any vacuum lines as when I did the motor would die, when it wasn't hooked up it ran great, so I don't see any reason to reinstall it and am going to just block the opening in the air intake, any thought on doing this??? Now the reed valve just what does it do and why is it in there. Is it just a glorified pvc valve ?? I have headers and the openings would be very easy to block off. I hope to get some answers soon as I am working on it today and I don't want to do any thing dumb
Old Oct 9, 2018 | 03:22 PM
Well I went ahead and pulled the EGR and the reed valve. blocked the lines, found out if you put 3 pennys in the fittings that were used by the EGR and Reed valve and put the nuts back on it works great. If it continues to run good I am going to leave it this way. The spark plugs on the passenger are in plane sight, sure easy to change.......
Old Oct 10, 2018 | 04:21 PM
thefishguy77's Avatar
At a bare minimum tell us what your working on.
We can be 100's even 1000's of miles from you. The more details you give the easier it is to answer your question.
Old Oct 10, 2018 | 05:58 PM
millball's Avatar
Certainly not saying that it won't run fair, but..
Taking parts off and plugging up the holes where they had been is not often the way to go with electronicly controlled fuel injection machines.
Neither the PAIR, nor the EGR rob the engine of significant power, and they play into the efficiency regime designed into the programming of the ECU.
Not only that, but the truck spews a little less nasty stuff when those systems work. Not too hard to make them right.
Old Oct 11, 2018 | 05:36 AM
scope103's Avatar
Originally Posted by grousehunter 61
... and I don't want to do any thing dumb
Originally Posted by millball
... Taking parts off and plugging up the holes where they had been is not often the way to go with electronicly controlled fuel injection machines.,,,
I agree with millball; someone a lot smarter than (most of) the rest of us combined designed your vehicle with all the parts to work together. Don't start taking them off unless you're smarter than Toyota's engineers.
I'm going to guess you're working on a 3VZE, and the problem you're having is getting the 25mm (approx) hose back onto the PAIR. My advice: heat gun. (Actually, a hair dryer will work.) Warm up the hose with the heat gun enough to make the rubber more pliable, and this job is MUCH easier. Put your hand on the hose as you're heating it; if it's too hot for your hand, it's too hot for the rubber.
Old Oct 11, 2018 | 08:25 AM
Thanks guys, normally I would agree but in this case, unless I run into trouble they are going to stay off. The reason they are off is the valve cover on the passenger side was leaking oil so bad the I was afraid it would catch fire. With those two things removed I can see the head and if the leak is going to recur. Changing the spark plugs is a dream. As I understand it the reed valve just puts fresh air back into the exhaust to lessen emissions, The EGR valve has never been hooked up, yes it was in the exhaust system and in the air chamber but was never hooked up to any vacuum lines, so it was serving no purpose.
You are right I never did say what I was working on sorry....its a 93 4runner with the 3.0 v6
So I am going to use it as is, if my gas mileage drops or any other problems arise then they may go back on and no I am not smarter the the engineers that designed the motor, but sometime they over engineer things trying to cover all bases. Now I understand the if you live in Calif you probably can't get away with this, but I live in the mountains of Idaho, hell we don't even have building permits or inspectors.
Old Oct 11, 2018 | 08:52 AM
No the problem was the hard line from the reed valve to the header it has to be bent in just the right way to allow the mounting holes to line up, easy to do when the motor is sitting on the motor stand but not when its under all the vacuum lines and installed in the car. At my age I am very short on patience and have been known to change the way things work.
Old Oct 13, 2018 | 08:47 AM
I may reinstall the reed valve, I noticed a loss of power. I pulled a trailer and it just didn't have the power it had with the reed valve, not sure why, but it didn't.
Old Oct 13, 2018 | 01:17 PM
Found the problem, forgot to block off one of the vacuum lines, plugs it and it back to normal.......
MaximRecoil
Feb 27, 2011 01:49 PM
shifty
Nov 14, 2007 03:54 PM
BOSTON4RUNNER
Nov 24, 2004 10:45 AM
Brad
Sep 25, 2003 06:05 PM
Los Gatos?
Apr 4, 2003 08:22 PM
