Post your GAS MILEAGE!!
Old Jun 24, 2013 | 05:52 PM
  #1621
old fart's Avatar
I have to budget, so I generally pop $35-40 in for pushwater, which gets me to 3/4 tank on the gauge. That lasts me 4 days, and on average I drive approx. 20 miles per day. It prolly doesn't help I have a really bad exhaust leak from the exhaust manifold. Needless to say, i'll keep it for the arctic winter driving, and i'm going to get a grand prix for summer later this week.
Old Jun 24, 2013 | 05:57 PM
  #1622
toyotaman2000's Avatar
You can't beat a Toyota really. Mine is not 4wd.. still I've had it forever seems like.
Old Jun 25, 2013 | 06:29 AM
  #1623
highntight's Avatar
last time i checked it got 23.3 mpg
Old Jun 25, 2013 | 05:52 PM
  #1624
ThatGuy1295's Avatar
highntight do you notice a difference in handling with your diesel motor weighing 350lbs pounds more then a 3vz?
Old Jun 26, 2013 | 08:12 AM
  #1625
highntight's Avatar
i ran the trail gear heavy duty springs. and its a 1 finger driver still. it handles really well still, even going down the highway. but it seems like 350 is way to more then actual weight. seems like when i looked it up it was only 200lbs heavier then stock v6. witch is really only a good sized person. i went and weighed it after the motor swap with a full tank of fuel and me in the truck and it was under 6k it seems like. the slip is in the glove box ill have to look again.
Old Jun 26, 2013 | 11:37 AM
  #1626
n16ht5's Avatar
19.8 mpg corrected (door tag says 225 tires) going over the pass to eastern WA. 37x12.50s w/ stock gears (5.29s are sitting on bench) 22RE 5spd with crawler cam, supra intake, header and full exhaust. I drive like there is no tomorrow.
Old Jun 26, 2013 | 09:24 PM
  #1627
shoe55's Avatar
Not sure what mine is yet, just purchased but its HORRIBLE...
91 4runner, 3.0, 31"
will be changing some things soon
Old Jun 27, 2013 | 04:17 PM
  #1628
JeffsJeep04's Avatar
93 22RE 5 speed
Cooling fan stuck on, passenger hub stuck locked in, gas cap missing, slipping clutch and timing floating around from missing guide. Still managed 21.6. More than happy with that. Put a gas cap on, clutch is going in tomorrow, and next weekend is timing and hopefully free up the fan while it's off. Should help significantly.
Old Jun 27, 2013 | 07:35 PM
  #1629
85Xtra-Cab's Avatar
I got the chance to drive very very slow in my 94 Pickup. hubs locked but not engaged, 4" lift, 33's, stock 4.10 gearing, 22re, driving 60 on the highway... I got exactly 250 miles on my tank of gas. So like 17mpg.
Driving fast and "normal" , 70 on the highway.. like 125-150 miles on a full tank. Sigh...
Old Jun 27, 2013 | 08:36 PM
  #1630
StewsRunner's Avatar
My new-to-me 95 V6 5SPD. I hit 15.15 MPG, 31s with 4:56, I drove a couple miles before resetting the trip-ometer, I made sure to not do that this time Also, that is a mix of highway, town, 4H and 4L so hopefully it'll bump up a bit if I don't go wheeling.
Old Jun 27, 2013 | 08:38 PM
  #1631
That's a huge difference! Time to factor in Toyota time to your day.. Toyota time: The added time needed to get to your destination, especially when trying to save fuel. haha
Old Jun 28, 2013 | 04:23 AM
  #1632
SPARKS89's Avatar
89 regular cab Pickup, 214,000+ miles, 22re, 5 speed, 4x4, 31.10.50 BFG AT's and stock 4.10 gears. The math on my last tank of gas showed 23.5 mpg, but i just replaced my TPS last week (I've been driving in safe mode for about a year and a half with a bad TPS since I bought the truck) and I've gotten more out of this tank of gas this week than I have before. I'll post updates once I do the math on the next fill-up.
Old Jun 28, 2013 | 05:59 AM
  #1633
SPARKS89's Avatar
Originally Posted by RobD
Dude, no offence meant, but the metric system isn't the work of "socialists". Oddly enough, it's a system based on certain logical, scientific standards. Such as 100 centimeters to one meter. There are 1000 meters to a kilometer. Zero celcius is freezing, 100 celcius is boiling.
Not quite as quaint as the 12 inches equals one foot deal, and three of them to a yard. Then there's 5280 feet to a mile. Or freezing at 32 farenheit and 212 degrees for boiling.
Nice system.
And by the way, I get roughly 12.5 liters per 100 kms. Which would be approximately 22.6 miles per Imperial gallon, or 18.82 miles per US gallon.
As you can see in my sig line, I'm running a 3.4 liter engine with 265/85R15...er, 33"x10.5"x15" tires.
My calculations also show that 8 out of 24 posts, as of this writing, are by Canadians, giving you 33.3% (or 1/3) of the posts from Canada, not the 90% you claim. Don't forget the 1 guy from Belize, which is not part of the US.
I know I'm quoting a 5 year old post, but I just gotta say...I like this cat.
Old Jul 1, 2013 | 06:51 AM
  #1634
highntight's Avatar
ha ha legend...... wait for it...... dairy.......
thats funny stuff....
Old Jul 1, 2013 | 08:08 AM
  #1635
scruffy390's Avatar
I have a 91 regular cab 4X4 with 235 tires. The Knock sensor is gone so I know that will retard my timing 10 degrees and possible richen the fuel (both not good on fuel milage) and I am not sure when the last time the oxygen sensor was replaced and injectors rebuilt. The truck is showing 200,000 but was told from previous owner it was not the original engine. I installed new plugs 3,000 -4,000 miles ago and recently replaced the air filter, fuel filter, plug wires, Distributor cap and rotor. The last 2 times I have filled the truck up I got 23 mpg. My question is this possible with the missing knock sensor or is my odometer or math off??
Old Jul 6, 2013 | 06:34 PM
  #1636
Washi's Avatar
Old Apr 26, 2014 | 08:41 PM
  #1637
Blackulua's Avatar
I posted my mileage before and for the latest report of my 88 toy sas built ,new head with stock cam on a high mileage block,r151f turbo trans,4-hole injectors from osetiger at ebay,265/70r16 MT baja stx tires on 4runner rims with 4:88 open gears and getting a amazing 23.79 mpg on city driving.
Old Apr 27, 2014 | 10:50 AM
  #1638
wallydrifter's Avatar
95 sr5 3.0 3vz-e 33 tires 2" lift 209,138 miles drove her home from Lincoln nebraska over 400 miles to my house got right at 15 mpg doing 75. Now it's all I can do to run 65 on the highway pedal to the floor, climbing a big Hill got to down shift out of od and hammer the gas, drive 12 miles a day to and from work half country road half town driving on a good tank I'll get 7 to 9mpg. Got to fill up every week at around 50 bucks s tank. Changed out plus and wires changed air breather. Next gonna tackle the exhaust and try the sea foam trick. Still just a bit better than my 01 Dodge with 35s and 4"lift that 100 bucks every other week
Old Jul 19, 2014 | 10:59 AM
  #1639
iamwieb's Avatar
I recently did a fill up and complete run out with my 95 toyota pickup with 33's, stock gearing, 301544 miles and I ran a tank for 245 miles. I'm not sure what the entire capacity of the tank is, I did find out that my light doesn't work, and I can be on or below E for about 20 miles.
Old Jul 19, 2014 | 08:41 PM
  #1640
OldernDirt's Avatar
Litres to Gal.s
Originally Posted by HelliphinoN8
Come on!! Are 90% of you from Canada?? We a$$-hole americans haven't quite adopted the metric system yet. If you can't post your MPG!! don't post. We have no clue ''aboot'' these things you call killometers, or liters. We're not socialists yet!
4 litres to a gal -don't be such an asshat to our Northern neghbors. and yes, you are an a$$-hole, as you say. go back to grade school, ignorant redneck!
