Obd1 17 pin to obd2 16 pin adapter question
Old Jan 23, 2015 | 01:23 PM
decalman's Avatar
Ok. Quick question
I have a bluetooth obd2 scanner
which works fine with newer cars using my android phone via bluetooth
my question is. If I buy this adapter
to connect it to my 87 22re pickup diagnostic plug, will it read anything?
thanks in advance
Old Jan 23, 2015 | 01:52 PM
scope103's Avatar
Almost certainly not. The protocols aren't even vaguely related.
So what is the adapter for? Beats me, and I own one.
Old Jan 23, 2015 | 02:52 PM
Punchy's Avatar
Will not work, The OBD1 diag port on the Toyotas is a sensor and switch junction, Not a data port as OBD2 is.
Old Jan 23, 2015 | 03:15 PM
scope103's Avatar
Originally Posted by Punchy
... Not a data port as OBD2 is.
No, the OBD1 port on our trucks IS a data port, it just requires some fancy footwork to read it. Fortunately, one of our members (RJR) has already done that: https://www.yotatech.com/forums/f116...reader-278801/
Old Jan 24, 2015 | 10:33 AM
decalman's Avatar
thanks. makes me wonder why would they build an adapter cable for it.
Old Jan 24, 2015 | 10:45 AM
bswarm's Avatar
Some scanners (Snap-On MT2500 for one) have connectors and software cartridges for different vehicles. I regret the day I sold my Snap-On Scanner, didn't think I'd need it anymore.
Old Jan 24, 2015 | 10:55 AM
millball's Avatar
My old MT-2500 scanner is a Godsend for the OBD1 Toyotas.
If you shop around for awhile on Ebay, you can get one with suitable cartridges and adapters for a couple hundred bucks. I run several different make pre-1997 non-standardised OBD cars and I don't know what I'd do without my old 'brick'.
They cost a bundle, back in the day.
Old Jan 26, 2015 | 06:34 PM
Punchy's Avatar
No its not, You cannot pull any codes from the Toy OBD1 port, You can only jump it and read the ENG dash light.
Old Jan 26, 2015 | 08:34 PM
millball's Avatar
I guess that you have never used a Snap=On MT2500 on an OBD1 Toyota.
It not only can read the codes, but the software contains a database of what the codes mean.
It may be true that the earlier OBD1 ECMs can give less info than the newest OBD1 ECMs can. I seem to remember differences between what can be got from my '87 and what can be got from my '95 truck.
I even read the TPS output on my '95 Runner and adjusted the TPS using my scanner.
Old Jan 27, 2015 | 06:45 AM
bswarm's Avatar
The MT2500 will read codes on just about everything out there. Even the 80's Fords that you were supposed to check codes with an analog swing voltmeter.
Old Jan 27, 2015 | 06:52 AM
decalman's Avatar
It's not cheap
http://www.ebay.com/itm/Snap-On-MT2500-Scanner-With-Manuals-Extras-Original-Hard-Case-Good-Cond-/111579766840?hash=item19faac2038&item=111579766840&pt=Motors_Automotive_Tools&vxp=mtr
Old Jan 27, 2015 | 06:58 AM
bswarm's Avatar
Originally Posted by decalman
It's not cheap
I paid $2k new almost 25 years ago. Had to have it, worked in a diagnostic shop and the Allen test POS wasn't cutting it. If you work in a shop it's a good investment.
Old Jan 27, 2015 | 07:20 AM
scope103's Avatar
Wow! Uh, not really ....
You don't need a $2,000 (or a coupla hundred) scanner. All you need is a $6 multimeter (you have that already) and the manual (here you go, for free: http://personal.utulsa.edu/~nathan-b...34electron.pdf)
A scanner is nice, mostly because you already have it and know how to use it. But for me, I'm not going to spend even a coupla hundred bucks on a "magic box." I would prefer to know just what signal I'm reading and what it really represents.
Plus, I'm cheap.
Old Jan 27, 2015 | 07:29 AM
bswarm's Avatar
Plus, I'm cheap.
It's really nice when you take a road test and can watch the scanner data in real world driving conditions. It paid for itself many times over. But like I said, if you work in a shop it's a good investment. I sold my Scanner and bought a cheap $20 code reader because I'm retired and have no use for it now. The MT2500 also had the code diagnostic procedure, no FSM needed.
kazuya2416
Apr 5, 2024 02:17 AM
rjtrials
Aug 6, 2015 07:25 PM
TJWilly
Jul 31, 2015 02:05 PM
msane99
Jul 17, 2015 10:13 AM
crashburnoveride
Jul 10, 2015 06:39 AM
