Noisy Cabin
Old Sep 19, 2008 | 08:13 AM
4RunnerKat's Avatar
Noisy Cabin
Howdy all! After doing a rear end swap on ole Gossamer, the noise level in the truck reduced substantially. Unfortunately now I hear a ton of engine noise, a bit excessive I think. Is this pretty typical for the 2nd gens 4Runmers?
Old Sep 19, 2008 | 08:42 AM
DeathCougar's Avatar
Define engine noises? And yea, its pretty typcial.
Old Sep 19, 2008 | 10:15 AM
space-junk's Avatar
yea, the engines are noisey... and what do you mean by "rear-end swap"?
Old Sep 19, 2008 | 12:31 PM
aviator's Avatar
These trucks do tend to be a little noisy. Try a search for B-Quiet sound deadening materials on the web, good products great prices.
Old Sep 19, 2008 | 12:33 PM
904_runner's Avatar
yup define noisy.
mines pretty loud, as far as fuel injectors go.
Old Sep 19, 2008 | 05:41 PM
4RunnerKat's Avatar
Nothing odd, just typical engine noise, loud acceleration, lots of outside noise, etc. I never noticed it before because I had bad bearings in the back for a while, and it was wicked loud. I swapped out the whole differential because I found a good used one for $150, it was cheaper to swap the whole rear end than to change the bearings, go fig!
Old Sep 19, 2008 | 08:03 PM
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
Try FatMat. Similar to Dynamat but way cheaper and a bit thicker i think.
Old Sep 19, 2008 | 08:44 PM
DupermanDave's Avatar
My suzuki sidekick was noisy as hell. But I loved the thing. I read a guide where someone created a noise proof barrier in his sidekick. He started by pulling up all the carpet. He then sprayed some of that bed liner in, and topped it with some noise dampening foam, and put the carpet back on. Added about an inch of thickness to the floor, but he said it reduced the outside engine noise to almost nothing.
These sidekicks are waayyy more noisy than the toyotas. Sounded like a lawnmower INSIDE the cab.
JNapolitano
Nov 14, 2019 07:46 PM
dbollier123
Sep 29, 2015 05:23 PM
ac7822
Sep 11, 2015 08:49 AM
elwood73
Jul 5, 2015 07:07 AM
thunderunner
15
Apr 19, 2003 02:56 AM
