ISR Mod Q's
Old Jun 4, 2007 | 01:58 PM
Kiff's Avatar
ISR Mod Q's
So Im doing the ISR mod, but I'm wondering, do I have to put the 2 vac hoses back into the intake? I know 1 is the valve cover vent, and I can just put a filter on that, what does the other do? is it just EGR?
Old Jun 4, 2007 | 05:45 PM
Kiff's Avatar
anyone? Also, what is the other bigger hose that goes to what looks to be a filter and then the air box.
Old Jun 4, 2007 | 08:11 PM
the_gunslinger's Avatar
do you have a third gen? if so, the frontmost baffle (with the vacuum lines) is the PERFECT size to use a spray paint lid. just drill a couple of 1/4 holes so you can still use the vacuum and wala (sp?) wahlah? hooplah?
Old Jun 4, 2007 | 08:18 PM
Tigerstripe40's Avatar
The other one is for the PAIR Reed valve.
if you don't hook it up, the engine compartment is noisy.
I mean, REALLY noisy...
I am thiking about making and selling some ISR pipes. The piece owuld be a mandrel bent piece of tubing, with welded bungs for the vac lines.
like this one
Would you be interested???
Old Jun 4, 2007 | 08:25 PM
i'd be interested if it came with heat wrap ...and fit a 5vz...and was cheep...
i'll probably end up making one, i've got a buddy that builds airplanes, and he might be able to fab one up out of carbon fiber...(it'll still get heat wrapped)
Old Jun 4, 2007 | 08:44 PM
Alex 400's Avatar
maybe how much? also how much difference does it make?
Old Jun 4, 2007 | 08:49 PM
curly_c's Avatar
id be interested
Old Jun 4, 2007 | 08:54 PM
yotasavg's Avatar
i made mine with no hose attachments. sounds and works fine. on the valve breather, i just used a little ricer-style filter and on the other one i just have the hose hangin'
Old Jun 5, 2007 | 06:24 AM
funjumper's Avatar
like this one
I have one of the ones that were made by Cootees. I never installed it. This is a mandrel bent ISR with the fittings for the vacuum hoses already installed.
I am doing a 3.4 swap, so I don't need it anymore.
US$50.00 shipped USPS P1 anywhere in the 48 states.
PM for more info. Price negotiable. Got any '96 3.4 intake parts to trade?
Old Jun 5, 2007 | 07:09 AM
Kiff's Avatar
I ended up making mine for under $25 CDN, not that there is much difference now, but just putting it out there, mandrel bent pipe from the auto parts store, hydraulic hose from the hardware store and some hose clamps I had.
And fore the 2 vac lines that go to the intake, I have a filter on the valve cover, we'll see how that works, people report a oil smell, some don't. The other is just chilling open right now. All the EGR stuff is the next to go!
Old Jun 5, 2007 | 09:08 AM
Schralper's Avatar
Mine ISR is 3" flex exhaust tubing ($13) w/ RPS 2.75" to 3" silicone connectors ($50 w/ shipping ) Not cheap but well worth the quality.
http://www.racepartsolutions.com/index.htm
I only welded a fitting for small hose near MAF (3/8" steel tube flared on one end pushed up thru hole drilled in pipe then welded). K&N filter off v.c., no smog check to worry about and then 5/8" hose + connector to airbox.
Then some black paint.
You sure can hear the MAF flutter at idle.
TheBFA
Feb 15, 2020 06:55 AM
voiddweller
53
Feb 1, 2016 05:46 AM
oldblue
Sep 28, 2015 04:07 PM
Project90
Sep 24, 2015 11:40 PM
Boomer8404
Sep 10, 2015 09:01 AM
